Broken antena
Discussion in 'General Tundra Discussion' started by gegs310314, Feb 29, 2020.
  1. Feb 29, 2020 at 11:00 AM
    gegs310314
    gegs310314 [OP] New Member
    St. Louis
    2019 Platinum
    Broke the whole antena off and screw is broken/stuck inside.... any rec on best way to extract?
  2. Feb 29, 2020 at 5:15 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Try using a screw extractor drill bit.It should't be in there to tight.
  3. Feb 29, 2020 at 5:19 PM
    You can get it out with a left handed/twist drill bit.
  4. Feb 29, 2020 at 5:22 PM
    It'll take you maybe 5 seconds to zip it out with a small left hand drill bit. Definitely not too tight in most cases as previously mentioned.
  5. Feb 29, 2020 at 6:26 PM
    gegs310314
    St. Louis
    2019 Platinum
    Thanks fellas. Wanted to make sure there wasn’t any secret toyota trick. All set and fixed.
    tundra nation!
  6. Feb 29, 2020 at 6:28 PM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    Yep left handed drill bit , possibly small ez-out !
