Broke the ECM connector clip thingy
Discussion in '2nd Gen Tundras (2007-2013)' started by drwilki, Oct 27, 2021.
  1. Oct 27, 2021 at 1:20 PM
    drwilki
    drwilki [OP] New Member
    David
    2008 Toyota Tundra
    Well, me being me I was removing all the wiring bits and pieces to pull the engine but then I decided to just do the head gaskets. Truck overheated and I guess everything got brittle and the ECM connector clip snapped off, now it is throwing 50+ codes and whenever it is pushed in it drops the codes down to like 5 and I am wondering if the clip and connecter can just be replaced or do I need a whole new harness. This is for a 2008 tundra 4.7l The clip in the upper left hand corner in the photo below
  2. Oct 27, 2021 at 8:38 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Don’t see your photo but I’m sure the connector can be de-pinned and replaced fairly easy by a qualified individual.
  3. Oct 27, 2021 at 8:45 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    look up the work manual and match the connector to it
  4. Oct 28, 2021 at 4:13 AM
    drwilki
    David
    2008 Toyota Tundra
    This is the connector in the upper left hand corner
  5. Aug 26, 2024 at 2:15 PM
    Aaron 45
    Aaron 45 New Member
    2018 tundra 5.7
    Let me know what you did i bought a used truck and found i have same problem i would push it in once a month and it wasn't a big deal but now it comes loose alot the new ecu is like 700 bucks and i just need the retaining bracket but seems to be a package deal
