Broke power steering pump bracket
Discussion in '2nd Gen Tundras (2007-2013)' started by Blantonsr, May 11, 2023.
  1. May 11, 2023 at 3:54 PM
    Blantonsr
    Blantonsr [OP] New Member
    David
    2022 Tundra 4.6L
    None
    So in trying to change the alternator, i had to loosen the PS pump and move it out of the way. The video I watched made it look easy, but that proved false. Anyway, as I was moving it down the bottom bolt hole on the bracket broke. After calling around I discovered the bracket is actually made into the timing cover, dealer price $1100.00. After market prices are lower. I am told the bottom mount hole is to stabilize the pump and the upper hole is what actually mounts it to the vehicle. So I have 2 questions; 1. Has anyone experienced this issue and how did you resolve it. 2. Is JB Weld an option.
    TIA
