Breather Valves?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ShawnTRD, Nov 11, 2023.
  1. Nov 11, 2023 at 7:00 PM
    ShawnTRD
    ShawnTRD [OP] New Member
    Shawn
    Going to get the underside of my 2020 Woolwax coated next week. Was thinking afterward would be a good time to replace the breathers on the trasfer case and front and rear diffs. On Sparks Parts I see the digram for the front and rear diff but I don't see them showing part numbers for these breather. Anyone know something about these?
  2. Nov 11, 2023 at 7:12 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Why do you think you need to replace them on a relatively new truck? You can always pull them off to give them a cleaning if you're concerned about it, also it might be a good idea to cover them with something before you get the undercoating sprayed.
    ShawnTRD[OP] likes this.
  3. Nov 12, 2023 at 6:16 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Might want to relocate your rear diff breather in the left taillight housing.
    HulkSmurf14 likes this.
  4. Nov 12, 2023 at 6:44 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Probably only rear diff needs to be pulled up to behind the DS tail light. Arb has a kit or you can DIY.
    bfunke likes this.
