Breaking her in the right way
Discussion in '3rd Gen Tundras (2022+)' started by EmergencyMaximum, Aug 5, 2023.
  1. Aug 5, 2023 at 3:33 PM
    EmergencyMaximum
    EmergencyMaximum [OP] Synthetic member
  2. Aug 5, 2023 at 4:29 PM
    Hella Krusty
    Hella Krusty New Member
    Unless you plan to own it for life......nothing wrong with that
    graf_von_tundra likes this.
  3. Aug 5, 2023 at 5:24 PM
    chaztizer
    chaztizer New Member
    2023 Tundra TRD Pro
    That’s actually cool. I’ve never seen stock trucks do those pulls. Only pretty heavily modified diesels. Now I wonder how much of a difference it would make for a hybrid Tundra to try that same pull.
  4. Aug 5, 2023 at 5:44 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
  5. Aug 5, 2023 at 6:44 PM
    EmergencyMaximum
    make some inquiries and get hooked up! (pun intended)
  6. Aug 5, 2023 at 8:08 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I want to know what the mpg’s were.
  7. Aug 5, 2023 at 8:19 PM
    EmergencyMaximum
    Fixed it for you:
    GPM's....gallons per minute.
    Mattedfred, Mater and TundraDan723 like this.
  8. Aug 5, 2023 at 9:54 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
  9. Aug 6, 2023 at 4:10 AM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    I don't figure Hybrid would make much of a difference. Because tires would be limiting factor in something like this pull.
    EmergencyMaximum[OP] likes this.
  10. Aug 6, 2023 at 5:09 AM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
  11. Aug 6, 2023 at 5:53 AM
    EmergencyMaximum
    Another one?!
    Man, no wonder their engines are blowing up left and right! We may have found the root cause!
    Kap1 and Black widow TRD like this.
  12. Aug 6, 2023 at 6:56 AM
    dodgemaniac
    dodgemaniac New Member
    Always cool to see what a new stock truck can do in a sled pull. Soft rear springs loosing hitch height also cost a lot of potential distance along with factory tires.
  13. Aug 6, 2023 at 9:49 AM
    EmergencyMaximum
    Ageed. Technically a higher sitting truck can pull longer because more clearance before shovel digs into the ground, ues?
    But you probably need super stiffness to prevent shovel digging into the ground..
    Leo's first likes this.
  14. Aug 6, 2023 at 2:14 PM
    gj953
    gj953 New Member
    East Coast
    2023 1794 Hybrid TRD OR Blueprint
    But they talk really funny in that second video... :) anyone know what he's(the announcer) saying? (and I grew up on the Quebec border, and mother's family is from Quebec... just not Canadian French based) ;)
    Silver17[QUOTED] likes this.
  15. Aug 6, 2023 at 9:48 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    The sleds weight and transfer speed up the sled is modified (by gearing) based on the horsepower of the vehicle doing the pulling.
  16. Aug 7, 2023 at 4:03 AM
    dodgemaniac
    You are on the right track but it is more about maintaining hitch height. One of the ways most of these classes are regulated is based on a maximum hook or hitch height along with what you are allowed to do with the suspension. A higher hitch height will pull up on the front of the sled more allowing you to gain more momentum before the transfer weight pushes the pan into the ground, along with more traction on the rear tire. If the class allow for it blocking rear suspension solid or limiting travel makes a big difference in maintaining this hitch height.
  17. Aug 7, 2023 at 8:49 AM
    EmergencyMaximum
    Interesting. I've also noticed a large counterweight in some videos on the front end of the vehicle. That effectively give more traction to the front and lift the rear a little bit. I haven't seen anyone do it before.
    dodgemaniac likes this.
  18. Aug 7, 2023 at 9:12 AM
    dodgemaniac
    Yes classes usually have a maximum weight limit, and moving that weight around to different points on the truck help with traction.
    Many years ago I used to compete in truck pulling, its not a tundra but this is a short clip from back then starting at 2:03.
