Break In Period.... Towing....
Discussion in 'Towing & Hauling' started by Greg Marmalard, Mar 25, 2019.
  1. Mar 25, 2019 at 7:38 AM
    Greg Marmalard
    Greg Marmalard [OP] New Member
    2019 Tundra TRD Off Road Double Cab
    Howdy,
    Well circumstances have me towing a 4000lb Airstream with a brand new Tundra very soon! I have 2-3 weeks before I hit the road for a long haul...
    Manual says don't tow for 500 miles and go easy first 1000.....
    I guess time doesn't really factor but I suppose I should maybe try to put some nice easy 65mph fwy miles on it asap.
    Any other break in tips?
    This is my first brand new vehicle!
    Thanks,
    Greg
  2. Mar 25, 2019 at 7:55 AM
    15whtrd
    15whtrd Mr. Blonde
    Personally I would want to put some miles on it to at least where Toyota recommends before you tow.
  3. Mar 25, 2019 at 7:58 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Dont drive at a steady speed for a long interval, vary speed. Easy on the brakes for the first few hundred miles. Even tho it is synthetic oil, I still do a oil change at about 1k. Enjoy your truck and Airstream!
    JohnLakeman likes this.
  4. Mar 25, 2019 at 8:05 AM
    dlos
    dlos Truckin'
    2019 Cement Off-Road
    Mods Mods Mods....
    I'd follow the manual recommendations for break-in and towing. I waited to tow until I had 1k miles. First tow was only 150 miles with a 22' boat weighing about 3500 lbs. Took it slow, varied speed and RPMs.
  5. Mar 25, 2019 at 8:15 AM
    Greg Marmalard
    No problem... I'm in Phoenix! :D
    Curious about brakes... I've added new pads and rotors before and don't recall any warnings about taking it easy.... Had to bed them which involved the opposite of what I'm told to do with a new truck...
    Thanks,
    Greg M
  6. Mar 25, 2019 at 8:24 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    No OEM makes an issue of bedding brakes, as far as I know. Bedding implies a certain protocol of increasing hard stops from increasing speeds. Probably not necessary for any brakes except high performance pads and rotors where the manufacturer specifies they be bedded. The Owner's Manual is pretty clear on this...just take it easy on them for the first 1000 miles.
  7. Mar 25, 2019 at 8:24 AM
    Scotty Dive
    Scotty Dive New Member
    Connecticut
    this thread caught my eye...I tow occasionally with a 16 foot dual axle trailer with a tractor, jeep., or firewood on it. Does anyone have any experience with towing and adding the rear sway bar?
  8. Mar 25, 2019 at 8:30 AM
    Nm6300'asl
    2022 DC SR5 4x4
    The manual states no hard braking for the first 250 (?) Miles or so. Yep, good luck in Pheonix.
  9. Mar 25, 2019 at 8:30 AM
    JohnLakeman
    Related thread already started. Ask here for more info:
    https://www.tundras.com/threads/sway-bar-question.41791/
  10. May 28, 2019 at 8:02 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    So, what’s the risk with towing too early?
    I towed a trailer with some ATVs on it with about 300 miles on the truck when I bought it new last year.
    Not really that much weight but I went over multiple mountain passes...
    Greg Marmalard[OP] likes this.
