Break-in oil changes...
Discussion in '3rd Gen Tundras (2022+)' started by MustangVetAMDO, May 5, 2025 at 6:02 AM.
  1. May 5, 2025 at 6:02 AM
    MustangVetAMDO
    MustangVetAMDO [OP] Some free advice; Don't.
    Andy
    Moyock, NC
    Prev. OG 2007 CrewMax, pres. 2025 Tundra 1794 Ed.
    Retrax XR Pro, Yakima Overhaul HD
    Back in the 'old days', my shop did break-in oil changes on new engines (500 miles in, and another at 1,000) then went from there....
    Just passed 1,000 on my 2025 that they say doesn't need oil till 10k; which I'm kinda-fine with, but my historically untrusting haunches make me want to drain, fill, and swap filters.
    Thoughts?
  2. May 5, 2025 at 6:05 AM
    Daedalus
    Daedalus New Member
    Change it. Cheap insurance.
  3. May 5, 2025 at 6:12 AM
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    I changed mine at 1,000. Currently changing my oil at 5,000 intervals. Makes no sense to wait to 10,000 no matter whatever engineer says. Gives me peace of mind.
    WILLINH, sudobash, BlackNBlu and 2 others like this.
  4. May 5, 2025 at 6:12 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    You will find many on here do a change around 1,000 and then at each 5,000 after that. The conclusion is that 10,000 miles is too long of an OCI for a turbo motor.
    I did mine at 660 and will do it again at 5,000.
    In addition to oil, filter, and crush washer, you will need a 15mm tube to attach to the oil filter catch.
    https://a.co/d/eV59oGD
    Right after you shut the truck off, hold the mist function on the wiper stalk to lower the front active spoiler.
    WILLINH and MustangVetAMDO[OP] like this.
  5. May 5, 2025 at 6:13 AM
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    I changed mine at about 900 miles and then I plan to change every 5k just for a peace of mind.
    WILLINH, Tom976, sudobash and 2 others like this.
  6. May 5, 2025 at 6:22 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I’m a rebel. I waited till 1700 miles before the first change and again at 5K. 5K intervals from here on out.
  7. May 5, 2025 at 6:37 AM
    MustangVetAMDO
    Andy
    Moyock, NC
    .....and the whole thing with the auto-spoiler....does every Tundra have that? I didn't even know that existed.
    sudobash likes this.
  8. May 5, 2025 at 7:18 AM
    sudobash
    sudobash New Member
    The vast majority do.
  9. May 5, 2025 at 7:22 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    If you have the TRD package with the skid it is deleted from the factory. Otherwise I believe all others have the spoiler.
  10. May 5, 2025 at 7:36 AM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    I did mine at 1000 miles, but I have a 23 and they were in the process of exploding at the time. I believe now though it was only the all gas motors coming out of the Alabama plant. At the time there was a lot of confusion saying the hybrids were failing too.
  11. May 5, 2025 at 8:25 AM
    Daedalus
    Daedalus New Member
    Not a good look for my State :/
  12. May 5, 2025 at 8:31 AM
    Don't believe that was confusion. Numerous examples of Hybrid equipped Tundras with motor failure. All the motors are made at the same place.
    GODZILLA and sudobash like this.
  13. May 5, 2025 at 8:41 AM
    sudobash
    sudobash New Member
    Appreciate the laugh this morning.
    GODZILLA likes this.
  14. May 5, 2025 at 8:59 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    The only reason the hybrids were not part of the recall is because the battery would keep the vehicle running and you wouldn’t stall and be left stranded on the freeway like the gas engines would. They are having the exact same issues.
  15. May 5, 2025 at 9:00 AM
    Except it really doesn't do that.
  16. May 5, 2025 at 9:02 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Exactly, plenty on here have said the same thing but that's what toyota told me when I took my truck in. Bs that they know of the issues and know it affects hybrids as well but they wouldn't add them to the recall. I'm not sure if they will eventually or not.
  17. May 5, 2025 at 9:43 AM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    Do whatever you feel comfortable with. Me? I change every 10,000 miles because I don't keep anything long enough to really care :burnrubber:
    Gonefishingdave likes this.
  18. May 5, 2025 at 9:49 AM
    Retroboy1989
    Northern Utah
    Good thing I don't buy black vehicles
    I never know when I going to have a long term or a quick turn around vehicle. Last one sold we had for 7 years.
  19. May 5, 2025 at 10:25 AM
    CHESSIEMAN
    CHESSIEMAN New Member
    STEVE
    PA
    2025 ICE CAP RALLY CREWMAX
    I have a 2025 Rally with the TRD package and it has the active spoiler.
  20. May 5, 2025 at 10:27 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Do you have the TRD skid? Maybe they made them work with each other for 2025.
  21. May 5, 2025 at 10:29 AM
    CHESSIEMAN
    STEVE
    PA
    It's the cheaper skid plate , not the aluminum one.
  22. May 5, 2025 at 10:35 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Something about the aluminum one that doesn't work with the spoiler.
  23. May 5, 2025 at 10:59 AM
    GREENPUS
    GREENPUS New Member
    Scott
    I'll rattle can spray it a different color so you'll never know :spy:
  24. May 5, 2025 at 11:01 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Not true.
    Plenty of TRD Offroads, mine included, with the TRD aluminum skid plate.
    Bought it that way.
    No interference whatsoever.
  25. May 5, 2025 at 11:05 AM
    Retroboy1989
    Northern Utah
    The rally package is a TRD OR with some extra goodies. OR has the plastic skid.
  26. May 5, 2025 at 11:14 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    You may be right, everything I've read says the active spoiler is removed when adding trd package as it's not an offroad accessory. But having only a truck with the trd package I can only verify that it did not come on mine.
  27. May 5, 2025 at 11:34 AM
    BlackNBlu
    Rich
    MN
    The TRD aluminum skid does not come as part of ANY package.
    It is included on the TRD PRO model.
    It is a stand-alone option on other trims.
    As far as the spoiler, we've seen it both ways, with and without.
    Not sure what the criteria is one way or the other.
  28. May 5, 2025 at 11:38 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    My truck has the trd package and it included the aluminum trd skid plate. It’s even written as part of the package on my window sticker. They change stuff all the time so it could be different now, but when I was shopping, all 22-23 that I looked at with the trd package had the aluminum skid.
  29. May 5, 2025 at 12:19 PM
    TRDoffroadPRO
    Numerous, rofl. Like your numerous troll posts claiming these issues? You own one? I do have a 23 that I bought brand new at 7 miles on it. Has almost 27 thousand miles on it and NOW and ZERO issues over 27 months of ownership. So, I would say you and your troll buddies have ZERO clues as to what you are talking about.
    Oh and the Alabama plant wasn't making the iForce Hybrid motor, they were coming out of the Texas plant at the time. They may be making them now with tariffs and all but I am not sure.
  30. May 5, 2025 at 12:24 PM
    :thumbsup:
    TRDoffroadPRO[QUOTED] likes this.
