Brass filings in trasmission pan
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nasty2sss, Apr 14, 2025.
  1. Apr 14, 2025 at 3:45 PM
    Nasty2sss
    Nasty2sss [OP] New Member
    Phil
    2016 sunsetbronze limited Tundra
    Leveling kit
    I have a 2016 Tundra limited that I took in for a transmission service new fluid and filter.The guy doing the work told me there was brass filings in the pan.Has anyone else ever experienced this?
    If so did the transmission fail? The guy told me everything else was fine.The truck shifts right and everything seems fine. He told me just drive it and don't worry about it.Anyone else have any thoughts on this?
  2. Apr 14, 2025 at 4:16 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    How many miles on truck? Have you ever done a tranny fluid change before? Did he flush it or drained and filled?
  3. Apr 14, 2025 at 4:28 PM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    1. He has no way to tell if they are actually brass.
    2. Probably normal wear material from years of usage and no fluid changes.
  4. Apr 14, 2025 at 5:12 PM
    Nasty2sss
    Phil
    Leveling kit
    126,000 miles first fluid change.I believe it was drained and filled
  5. Apr 14, 2025 at 5:46 PM
    MadMaxCanon
    At that mileage it's totally normal.
  6. Apr 14, 2025 at 5:51 PM
    Nasty2sss
    Phil
    Leveling kit
    thanks so I should have no worries love this truck,It will be 10 years old in December.No problems at all.I have a 22 also which I also love, just waiting to be called for the engine swap
  7. Apr 14, 2025 at 5:58 PM
    I wouldn't worry about it. If you are, do a couple more drain and fills to clean every thing out.
  8. Apr 14, 2025 at 5:58 PM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    Good call on tyranny service. Mine started acting up before 100k. Did flush at the dealer and she felt like new again. Currently almost 150k.
