Brand new to the forum
Discussion in 'New Member Introductions' started by Hoodrat_tundra, Aug 20, 2022.
  1. Aug 20, 2022 at 7:25 AM
    Hoodrat_tundra
    Hoodrat_tundra [OP] New Member
    Allen
    2011 Toyota Tundra
    Engine: Koyo radiator Koyo radiator cap Mishimoto radiator hoses Brand new oem thermostat K&N aluminum pipe (Wrapped in gold DEI heat) AFE Throttle body spacer Bullydog tuner New oem spark plugs 80,000miles New valve cover gaskets 80,000miles Sdhq window reservoir relocation kit Sdhq billet power steering reservoir New steering rack 78,562 miles Energy star steering rack bushings New interstate battery Sdhq billet battery terminals Sdhq billet battery hold down New oem belt 80,000 miles New Oem tensioner 80,000 miles New oil filter aluminum housing vs old plastic New oem charcoal canister 2014+ Conversion: All conversion parts are Toyota oem hood Grille Hood scoop Radiator support Hood supports Tailgate Latches Rubber bushings Radiator Cross member Updated backup camera And many other parts to convert it properly Interior: Cardinal red katskin leather Dynamat sound deadening and liner all around cab Ceramic two layer window tint Ceramic windshield tint Two jl 12” shallow subwoofers Shallow under seat 2 12” box Jl audio 1000 watt amplifier Rockford fosgate speakers 6.5” all 4 doors Rockford fosgate (x2) 3.5” dash speakers Toyota first aid kits (x2) Sony xav-ax7000 touchscreen headunit Sirius xm added to head unit Switch-Pros 8 switch panel Sdhq sunglasses Switch-Pros mount Ajt climate controls in black Ajt key guard Diode dynamics led interior lights New oem door weatherstripping Exterior: (Truck was just painted in early August ) Advance fiberglass fenders front & rear Custom tow mirrors color matched to paint Avs low profile door vent side/rain guards color matched Camburg black fender bolts& washers kit Line-x inside fenders front & rear Bed line-x Outside Bed sprayed in sound deadner C4 fabrication overlander front bumper Factor55 1.5 fairlead Factor55 ultra hook in blue Mazulla pre runner rear bumper Baja design -30” light bar in combo -(x2) fog lights squadron -(x2) reverse s2 pros -hood light -(x2)s pod wide pattern reverse/chase lights -(x2) LP9’S in combo (X2) Sdhq billet chase light mounting kit Smittybilt shackles (x2) Smitybilt x20 gen3 10k synthetic rope winch ARP 12 point bolts used for mounting hardware on any expose Baja design lights Hella horns painted in black New third brake light Alpharex taillights in smoked lens Alpha owls headlights Rci skid plates 1/4” 5052 aluminum raw/polished mirror finish engine, Transmission/ T-case skid plate package Rci Lower control arm skid guards Amp research powersteps Bed courtesy lights Victory 4x4 Molle back panel Rotopax 1 gallon water Rotopax 3.5 gallon gasoline Maxxtraxx recovery boards in black Suspension: Camburg upper control arms Fox 2.5 dsc coilovers Fox 2.5 Dsc rear shocks Trd away bar front & Rear Deaver leaf springs k37 Camburg 1.5” lift shackles Camburg bolt on bump stop kit with 2.0 fox bump stops Sdhq traction bars for double cab Duro bumpstops New oem tie rods Diff drop Relentless fabrication Cab mount chop Ark splash guards Brakes: Stop tech slotted and drilled rotors Stop tech break pads Sdhq extended break lines Sdhq Abs guards Wheels & tires: Method MR316 18x9 (x5 wheels) 18 offset Geolander Yokohama 305/70 R18 (35”) Brand new 315HZ TPMS sensors Sdhq tire strap Bora 1.25” wheel spacers
    9064157B-AFDE-4C64-96D6-DF10ED544300.jpg A69DE322-6F29-454A-AC27-C257EF87FCE6.jpg Hello everyone,
    My name is Allen and I finally made an account on here after browsing for inspiration/assistance roughly a whole year.
    I purchased my 2nd Toyota tundra last year in April and started building it as soon as I got handed the keys.
    Within the first month I had a 2.5” ready lift kit spacer for the front
    With some method MR316 18x9 +18 wrapped in Yokohama geolanders XAT’s 315/70R18.
    Since that first month to just about a week ago here is how she sits now.
  2. Aug 20, 2022 at 7:28 AM
    Hoodrat_tundra
    Allen
    2011 Toyota Tundra
  3. Aug 20, 2022 at 7:34 AM
    Welcome from NY.
    Hoodrat_tundra[OP] likes this.
  4. Aug 20, 2022 at 7:45 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. Aug 20, 2022 at 8:09 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Welcome from Northern California.
  6. Aug 20, 2022 at 3:40 PM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    Welcome and greetings from Minnesota. Your truck looks great.
  7. Aug 20, 2022 at 3:47 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  8. Aug 20, 2022 at 3:55 PM
    What year is the 2nd one?
  9. Aug 20, 2022 at 4:11 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  10. Aug 22, 2022 at 4:06 PM
    Hoodrat_tundra
    Allen
    2011 Toyota Tundra
    Hi George,
    They’re both the same truck I just converted it to the newer body style.
    The year of the tundra is a 2011.
  11. Aug 22, 2022 at 4:12 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Welcome from SW Florida!
  12. Aug 22, 2022 at 6:06 PM
    Wow...I was wondering that once I saw the bed and tailgate. :thumbsup:
  13. Aug 22, 2022 at 7:18 PM
    Did you do an interior swap as well? :D
  14. Aug 22, 2022 at 7:20 PM
  15. Aug 22, 2022 at 8:33 PM
    pjh183
    pjh183 New Member
    Patrick
    2014 Tundra
    Welcome
  16. Aug 23, 2022 at 7:17 AM
    Hoodrat_tundra
    Allen
    2011 Toyota Tundra
    Nope interior is stock gen 2 interior but I did install leather seats.
  17. Aug 25, 2022 at 4:30 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
