Brand new, 2 questions 2022 tundra. (4wd and “comfort+”)
Discussion in '3rd Gen Tundras (2022+)' started by Oldandfat, Feb 26, 2022.
  1. Feb 26, 2022 at 5:28 PM
    Oldandfat
    Oldandfat [OP] New Member
    Cannuckastan
    2024 SR5 TRD Offroad Lunar Rock
    Hi guys. Brand new. Hoping to replace my 2012 frontier with a “big boy” truck.
    Managed to find a 2022 tundra to sit in. Had some questions the sales guy couldn’t answer and I somewhat found some answers here, BUT they pertain to 2021 and older. Not sure how much has changed.
    1. How does basic Toyota 4wd work? (Not offroad stuff I.e crawl, multi, etc). My Nissan is open front and back diff, transfer,case. But the axles have ABLS which is active braking (abs in reverse) to mimic lsd.
    Toyota atrac seems the same? Does the new tundra have this?
    2. Multi,surface…. 4wlo only?
    3. Comfort+ is available on all trims except trd offroad. Why? Sales guy didn’t know.
    I’m not an off-roader. I just need a truck that will get me through lots of snow (roads) and I really like the idea of an integrated block heater, trickle charge, and interior warmer.
    offroad trim deletes the comfort but I gain the multi surface (assuming I can use it in 4whi)
    can I assume that any 4wd posts also pertain to the newest tundra generation? Or did they significantly change anything?
    TK1979 and 4genRunner like this.
  2. Feb 26, 2022 at 5:57 PM
    Breathing Borla
    AZ
    I think you win the award for the amount of questions in a first post ,ha!
    welcome
    2022mgmTundra, bigjuice and TK1979 like this.
  3. Feb 26, 2022 at 6:15 PM
    Oldandfat
    Cannuckastan
    Damn, had I known that I’d have asked a lot more to lock it down!
  4. Feb 26, 2022 at 6:19 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! Plenty of 3rd Gen related information to answer your questions on the 22 Tundra
    TK1979 likes this.
  5. Feb 27, 2022 at 6:24 AM
    xc_tc
    xc_tc New Member
    Tundra diffs are open unless you get the TRD Off-road package which has a rear locker optional. Only the 2WD truck has an “Auto LSD” function, but it’s basically traction control so 4WD trucks technically have it. But no ATRAC, the traction control system fills in for this function. Only TRD Off-road has the multi-terrain select and crawl control. You can use it in 4Hi and 4Lo but not all the modes. Lastly, Comfort mode (and Sports+, maybe you’re mixing the two together) are only available in vehicles with the adaptive variable suspension which cannot be paired with TRD off-road package.
    TK1979 likes this.
  6. Feb 27, 2022 at 6:30 AM
    Breathing Borla
    AZ
    So the platinum has ALsd again, no locker right?
  7. Feb 27, 2022 at 6:59 AM
    Oldandfat
    Cannuckastan
    so if I buy an sr5 tundra 4 x 4 it’s actually a 2 wheel drive truck? What happens when the tires slip?
    when I say “comfort” I. Referring to the comfort accessory block heater, trickle charger and cabin warmer, NOT drive system or suspension.
    sales guy said it can’t be installed in the offroad package. Didn’t make any sense to me.
    ‘do you have any links for the 2022 tundra 4wd systems?
  8. Feb 27, 2022 at 7:42 AM
    xc_tc
    xc_tc New Member
    Oh, the comfort+ package you mention is a Canadian thing. I have no idea why it’s packaged the way it is.
    Toyota website says all vehicles have Auto LSD (brake grabs wheel without traction so that wheel with traction can output torque). But the manual says only 4x2 trucks have Auto LSD.
    Tundras are part time 4WD. You have to select it… if the wheels slip, traction control intervenes and applies brakes/reduces engine power. It works fairly quickly and does an ok job.
  9. Feb 27, 2022 at 7:51 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    One thing you will notice from your old Frontier is that the 4WD on Tundra will take longer to engage and may require you to move the truck slightly. Your old Frontier doesn't use a actuator in the front differential so engagement is very quick. The Tundra uses and actuator so it will take a little more time to engage and can be finicky at times.
    Black Wolf likes this.
  10. Feb 27, 2022 at 8:09 AM
    Osiris
    Osiris New Member
    20 Plat
    Yeah, sometimes you also have to be on level ground before switching 4W modes. That's why you want to select it before you need it. The manual tells you to enable it once a month to keep the actuators and BorgWarner chain in the transfer case from seizing up.
    Tundras with or without multi-terrain select have ABS traction control permanently whether in 2WD or 4WD. The selector just changes how it behaves. 4lo has less aggressive traction control and was almost completely disabled in prior gen models(despite the icon being orange).
    21min in: https://www.youtube.com/watch?v=EKRlBoj0s7E
    Ruggybuggy likes this.
  11. Feb 27, 2022 at 2:26 PM
    Oldandfat
    Cannuckastan
    I’m trying to understand why the comfort stuff isn’t available in the trd offroad. Makes no sense.
    so if the tundra has auto lsd then it’s the same as my,frontier.
  12. Feb 27, 2022 at 2:27 PM
    Oldandfat
    Cannuckastan
    What does my frontier have, if not an actuator?
  13. Feb 27, 2022 at 3:52 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The Frontier just doesn't use an actuator. There is no axle disconnect used. Basically like the rear axle but on the front. Toyota uses a disconnect to try to obtain better mpg but the gain is minimal. The issue with the Toyota is that both the actuator in the transfer case and front diff have to lock before you have 4WD. With colder weather the front actuator can be troublesome to slide the collar in position to connect the axles or if the collar isn't quite lined up on the splines you may have to move the truck a touch for it for fall into place.
    TTund16 likes this.
  14. Feb 27, 2022 at 5:13 PM
    Osiris
    Osiris New Member
    20 Plat
    Comfort adjusts the airbag pressure in the rear, which TRD packages don't have.
  15. Feb 28, 2022 at 7:54 PM
    Oldandfat
    Cannuckastan
    Post #7:
    comfort package is the cabin warmer, block heater, trickle charger and Bluetooth controller. Nothing to do with suspension.
    It makes no sense why the offroad package can’t have it?
  16. Feb 28, 2022 at 7:56 PM
    Oldandfat
    Cannuckastan
    so if your driving while shifting into 4x it’s not an issue? If I’m at a dead stop and decide I need to go into 4x do I switch into 4x and it will do so as I drive?
  17. Mar 1, 2022 at 5:42 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Switch to 4H on the go is not a problem for either vehicle. Switching to 4LO on either vehicle required that the vehicle be stoped.
    TTund16 likes this.
  18. Mar 1, 2022 at 6:31 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    And in neutral. It works better for me to fully engage 4hi first. When I owned Fords they would engage 4lo in park but with the Toyota I put it in neutral.
  19. Mar 1, 2022 at 7:28 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I do the same. In neutral 4LO seems to engage easier.
  20. Mar 1, 2022 at 8:37 AM
    Oldandfat
    Cannuckastan
    yes, I understand that. I was asking in the context that Toyota sometimes “has to move a little” to get into 4x. If I’m driving then it’s not an issue. I’ll be “moving” as I’m driving. If that makes sense?
  21. Mar 1, 2022 at 9:13 AM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    Put it into 4hi anytime you want. Preferably not while sliding backwards down a slick road.. just understand if your not moving and it doesn’t click in that’s normal. It will once you move a little, eventually.
  22. Mar 1, 2022 at 9:19 AM
    Slicer97
    Slicer97 New Member
    Giddings, TX
    2022 Tundra SR5 TRD Off Road
    Thus the reason you shouldn't build a vehicle, particulary one that has an off-road package, that lacks front end recovery points...
  23. Mar 1, 2022 at 9:56 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yup. Driving in 2WD and get stuck then switch to 4WD and the front actuator can't engage the front diff. Well I'll just give it a tug from the front with my buddies truck. Nope.
  24. Mar 1, 2022 at 10:09 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    And one should be open so you can put the loop of your strap on it without using additional hardware.
    Slicer97[QUOTED] likes this.
  25. Mar 1, 2022 at 10:19 AM
    Will816
    Will816 New Member
    Will
    Idaho
    2022 Limited iForce Max TRD Off Road
    I think it’s mostly a matter of getting teeth or splines in the mechanism synchronized enough for everything to engage. Sometimes it slips right in, sometimes you need to roll forward or back 6 inches, and sometimes you need to straighten out and move a bit so any imbalances in load or shaft rotation can equalize
  26. Mar 1, 2022 at 10:32 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I believe you need to be in 4Lo to engage the factory rear locker.
  27. Mar 1, 2022 at 11:15 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Correct
  28. Mar 1, 2022 at 12:02 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    That is how my Tacoma worked. I hated the fact that it had to be in 4lo.
  29. Mar 1, 2022 at 12:09 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Toyota does that for safety reasons. They want to make sure the locker is only at low speeds.
    Terndrerrr likes this.
  30. Mar 1, 2022 at 1:41 PM
    Toyota1234
    Jack
    If your on a back road and didn’t have the forethought to put it in 4hi before hand then maybe damaging your front bumper by pulling from a control arm is probably the least of your worries. My point is it’s pretty hard on your cv axels to do so.
