Brakes & Rotors Under 20K Miles
Discussion in 'General Tundra Discussion' started by JayEnDubya, Oct 4, 2018.
  1. Oct 4, 2018 at 7:18 AM
    JayEnDubya
    JayEnDubya [OP] New Member
    2017 Tundra SR5 TRD Off-road 4WD
    Hello Fellow Tundra Enthusiasts. I'm looking for your help.
    I have a 2017 SR5 TRD-Offroad Crewmax that has approximately 18900 miles.
    This past weekend I was out driving in AZ on US-60 between Apache Junction and Globe when I noticed some significant front- end shaking while downhill braking. Those roads can be tough in some spots so I waited for a level patch of smooth road to check and sure enough at 55mph, there was slight shaking.
    Took it to the dealership and they confirmed that the brake pads were worn and glazed and the rotors were warped and needed machining.
    I didn't think those 18K miles were hard miles and asked if this was covered under the warranty (nope) Service Mgr told me it's a big truck and these brakes don't generally last more than 30K miles.
    I don't ride the brake and I downshift where I can. I don't buy the "it's a big truck" explanation because the F-150 I owned before this went 90K+ without needing brakes or rotors.
    Anybody else experience this? Is this common with Tundras?
  2. Oct 4, 2018 at 7:50 AM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Yup. I’m at 18k on my 2016 and it’s doing exactly that. Looking for brakes and rotors now.
  3. Oct 4, 2018 at 7:53 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm a little under 50% with 32k mi. No, after having 5 Tundra's, I'm not buying that line.
    1UPPER, 4Runner, Ike74 and 3 others like this.
  4. Oct 4, 2018 at 7:57 AM
  5. Oct 4, 2018 at 8:20 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Had the exact thing happen on my 2016 and the service manager told me the same about it being a big truck and small brakes but I don't buy it. They turned the rotors and replaced the pads as warranty. It started on mine around the same time ~18-19K when I was braking downhill. Huge steering wheel shake only when braking and was much worse going downhill the on flat ground. Check out the TSB below it might help at the dealership
    https://static.nhtsa.gov/odi/tsbs/2016/MC-10087869-5448.pdf
  6. Oct 4, 2018 at 9:22 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Mine are doing the same, started around 30k for me and I'm at 35k now. I will probably go to and EBC set like I installed on my Tacoma.
  7. Oct 4, 2018 at 9:25 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    That TSB is pretty open ended, either they are going to ask you some qualifying questions which they can then use to decline warranty work or they are aware of the issue and keeping track of things.
  8. Oct 5, 2018 at 3:16 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    My original rotors lasted 89k til they needed turning. Replaced them at 98k. Good luck. D
  9. Oct 5, 2018 at 4:43 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I changed my pads and rotors at 80K and I probably could've gone another 10K pretty easily.
    18K just doesn't sound right.
    Ike74 likes this.
  10. Oct 5, 2018 at 7:30 AM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    EBC slotted rotor on my gen 1 :thumbsup:
    bmf4069 and ColoradoTJ like this.
  11. Oct 5, 2018 at 8:15 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    I swapped pads/rotors on my gen 2 at 70k, and they still had plenty of life left
  12. Oct 5, 2018 at 8:23 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Had to have my rotors turned at 25,000 miles but pads were fine
  13. Oct 5, 2018 at 8:32 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    It is open-ended like you said but they turned mine and replaced the pads free of charge for me so maybe the OP can do the same and get some more life out of them. Replacing brakes and rotors at 18K is not normal and the reason "because toyota engineers designed too small of brakes for the tundra" I feel is inaccurate and a cop out for the service manager
  14. Oct 5, 2018 at 8:45 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    I called my dealer after reading this post. My 16 Crewmax 4x4 has just under 30,000 mi and my front brakes squeel and the wheel has a slight shimmy to it. The service mgr said they only warranty the brakes for 6 mos or 6000 miles, sounds like B.S. to me. He said it's likely the pads are fine, but the rotors will need turned...Apprx a $ 320.00 job, arggghh!
  15. Oct 5, 2018 at 9:08 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I've mentioned this in other posts. My brakes did the same thing at around 11,000 miles. I had experienced this on other vehicles in the past also. There is a lot of argument on the forums about what causes this. Some claim that the rotors are "warped" - but it takes an awful lot to truly "warp" a rotor. Another theory is that uneven deposits get put on your rotors during hard stops. It is these deposits that cause the problem. Anyway, whenever I notice this, I just go through a rebedding procedure like the one described in the video below (long video, but good explanation). I have posted the video a few times in the past, but the method works for me so I think it is worth posting again:
    https://www.youtube.com/watch?v=pdPX6rzuINc
    BTW, I am currently at about 70,000 miles on my original brakes. No issues. I have felt this vibration under braking twice with my Tundra. Rebedded and both times and it took care of the problem. Your results may vary.
    UNTMatt, Jengel451 and lewi3069 like this.
  16. Oct 9, 2018 at 9:46 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That doesnt sound right. My 13 E250 work van weighs in at 7700 lb and I tow a 5000 lb trailer about once a week. I usually have to do my brakes every 30k miles.
  17. Oct 9, 2018 at 9:50 AM
    TheBeast The Beach
    my rotors were wrapped around 48K. upgraded to stop tech slotted rotors and ceramic pads.
  18. Oct 9, 2018 at 12:12 PM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    "Too small of brakes"...I also call b.s. 13.9" rotors in the front, 13.6" in the back. How large should they be?
    scpete24[QUOTED] likes this.
  19. Oct 9, 2018 at 12:44 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Exactly.... big enough to stop the Space Shuttle... maybe that was just pulling it...
  20. Oct 9, 2018 at 1:46 PM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    I have 80K on my 2015 DC for and the brakes are fine . I don't make hard stops and drive it pretty easy .
  21. Oct 9, 2018 at 2:11 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Mine shakes a little too. I should bring it in for the tsb.
    Anyone ever change their brake fluid at home? Manual says it should be changed every 30k miles. Figured if I have the tsb done I can get a quote on them doing the fluid while they're at it. Doesn't seem like a simple job, not without investing in a fairly expensive tool anyway.
  22. Oct 9, 2018 at 2:52 PM
    Atomic City Tundra
    Devin
    New Mexico
    Fluid isn't that hard to change at all. Just get a power bleeder and an adapter like this one:
    https://www.amazon.com/Power-Probe-BA10-Adapter-Toyota/dp/B004IQ96RK
    Pudge[QUOTED] likes this.
  23. Oct 9, 2018 at 3:00 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    9 times out of 10 the rotors are NOT warped. Make them throw a dial indicator on it and show you the run out. I bet they dont have one handy.
    Most of the time the rotors do load up pad material unevenly so you get an uneven drag.
  24. Oct 9, 2018 at 3:03 PM
    Professional Hand Model
    Hand Protectors
    Do the turkey baster and fill flush. Takes a few times to get the fluid renewed and can be done at home over a period of two days. Its cheaper and easier than the shop doing it. Just suck out the reservoir and squeeze it in an old bottle. Top off with new and repeat after a few drives over a day or two.
    Been doing this with the trans fluid as well.
  25. Oct 9, 2018 at 3:20 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    I'm at 28K miles, a lot of them hard/fast off-road driving, carrying a LOT of weight in gear, running 35" tires, and just about to change my original factory pads but they're really not even squeaking yet.
  26. Oct 13, 2018 at 6:11 AM
    nowayout
    nowayout New Member
    NY
    17 CM
    I would go with a reputable company like EBC if you are replacing your brakes. They have a history of being quality and plenty of offload guys with bigger tires run them.
    Stay away from these fly by night companies that have no reputation except for their own reviews.
