Brakes pull right, new calipers, pads, and, lines
Discussion in '1st Gen Tundras (2000-2006)' started by ifox, Feb 4, 2020.
  1. Feb 4, 2020 at 4:28 PM
    ifox
    ifox [OP] New Member
    2001 tundra v8 4.7 4wd
    2.5 in lift kit
    Hi new to the forum trying to find help. My 2001 4wd toyota tundra at 250k miles, pulls right when I brake. I just changed both calipers and it still does it, I went ahead and changed the pads while I did, rotors appeared to be fine. And it still does it. I took it to a brake shop to have everything inspected and they said it would be a matter of process of elimination and to change the lines, so I did that myself. Still does it. Suspension seems to be fine I just put a lift kit on and had and alignment done after but did not change the issue at all and my suspension seems to be in perfect condition when I took it apart. So new calipers, new pads, new lines, it is fully aligned, my suspension is good...and yes I've bled them. Any ideas before I go to a shop again? Thanks for anyone who took the time to read this
  2. Feb 4, 2020 at 4:32 PM
    68vert
    68vert New Member
    AZ
    2011 Rock Warrior
    did you bed the pads? years ago I put brakes on my Camaro, didnt bed the pads. It stop poorly and pulled. 5 minute fix from my friend whom was a technician at a nearby chevrolet dealer. LOLs
  3. Feb 4, 2020 at 4:48 PM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Maybe a clog. Take the hose off the caliper and push hard on the brake pedal and blow it out. Maybe a fluid flush. Check the rear brakes as well.
  4. Feb 4, 2020 at 5:19 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Appearances can be deceiving. You have a braking problem and change everything but the rotors. Change the pads and rotors.
  5. Feb 4, 2020 at 5:22 PM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Correct, always change the rotors with pads.......but 1% chance that's the problem.
    Aerindel likes this.
  6. Feb 4, 2020 at 5:40 PM
    speedtre
    speedtre New Member
    Inland Northwest
  7. Feb 4, 2020 at 5:44 PM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    I didn't see my issue.......every time I go by this one bar my truck vers to the right.:goingcrazy:
    SMTundra and bmf4069 like this.
  8. Feb 4, 2020 at 5:53 PM
    Professional Hand Model
    Hand Protectors
    speedtre[QUOTED] likes this.
  9. Feb 4, 2020 at 5:54 PM
    Hand Protectors
    Krispy Kreme is always good for solid a right turn.
  10. Feb 5, 2020 at 9:32 AM
    ifox
    2.5 in lift kit
    @zombie all new lines. And @speedtre thank you that article seems to point me in the right direction, thanks for the help I'll update if I figure it out
    speedtre likes this.
  11. Feb 5, 2020 at 11:24 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I agree with @zombie and @PCJ, you should change the rotors cause you've updated everything else on the wheel brake wise. I would just go ahead and change the rotors and pads together (even though you just replaced the pads), cause it's not that expensive ($65 and up for rotors and pads) and easy to do...be sure to bed the pads.
    https://www.rockauto.com/en/catalog...brake+&+wheel+hub,rotor+&+brake+pad+kit,13824
    Now, if your problem happens to be that your glazed a rotor with your old calipers that were sticking, this may solve your problem, if not, my money is on a worn suspension/steering part on the side your pulling to...good luck. :thumbsup:
  12. Feb 7, 2020 at 7:18 PM
    Connor33
    Connor33 New Member
    Connor
    Try swapping tires see if the pull goes to the left
    Volt92 and tvpierce like this.
  13. Feb 8, 2020 at 9:56 PM
    Volt92
    Volt92 New Member
    Tulsa, Oklahoma
    2011 White Tundra RW
    2.5” level kit. 35” KO2
    Recently have this same issue but mine occurred after a tire flip on new wheels. They might have kinked a brake line somehow. Don’t know if tires would only pull while breaking. ‍♂️ Still trying to figure it out. Don’t want to throw money brakes if I don’t need to. Let us know if you find the issue ! Thanks!
  14. Feb 10, 2020 at 11:02 PM
    ifox
    2.5 in lift kit
    It was the tires, right side tires were balled on an edge
    Connor33 and Volt92 like this.
  15. Feb 11, 2020 at 12:01 AM
    Volt92
    Volt92 New Member
    Tulsa, Oklahoma
    Sweet. Looks like time for a new set for me. Or my excuse but I’m almost positive I have this same issue. I have new upper control arms coming to help the geometry with the level kit up front and hopefully a little less tire wear. 285s this time. Lol
  16. Feb 11, 2020 at 5:55 AM
    speedtre
    speedtre New Member
    Inland Northwest
    That sounds like a symptom of the problem that may contribute to the symptom of pulling to the right while braking, not the problem itself. Tires wear unevenly because there is a problem with the suspension/steering/alignment. After you add the new tires get it aligned and hopefully it's just an alignment issue and not a worn suspension/steering component that needs to be replaced.
    PCJ, FirstGenVol and BubbaW like this.
  17. Feb 11, 2020 at 12:04 PM
    ifox
    2.5 in lift kit
    @speedtre the ball came from a long time ago, I got the tires like that and the alignment was off, so I rotated the tires and had an alignment this is where they've sat since then.
  18. Feb 11, 2020 at 12:15 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Ok, well in that case, hopefully your done...:thumbsup:
  19. Feb 12, 2020 at 7:12 AM
    Connor33
    Connor33 New Member
    Connor
    Hell yeah iv seeing it a bunch of times in the shop guys throw money at the brakes and then turns out they had a bad alignment !! I’m glad it worked man!!
