Brakes-Grease Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rocko9999, Jan 18, 2023.
  1. Jan 18, 2023 at 8:28 AM
    Rocko9999
    Rocko9999 [OP] New Member
    I need to do my front/rear brakes and I want to know what is the best grease for the caliper slide pins, pad mounting tabs and back of pads. Superlube seems to be brought up frequently but some also say some anti-seize for the back of the pad and pad guides. What's your experience?
  2. Jan 18, 2023 at 8:37 AM
    2mchfun
    I use sil-glyde
    TWJLee, PKFan and Rocko9999[OP] like this.
  3. Jan 18, 2023 at 8:38 AM
    Rocko9999
    Do you use this for all parts-slide pins, backing plate and pad guides?
  4. Jan 18, 2023 at 8:39 AM
    2mchfun
    Correct
    Rocko9999[QUOTED][OP] likes this.
  5. Jan 18, 2023 at 8:40 AM
    Rocko9999
    Thanks.
    2mchfun[QUOTED] likes this.
  6. Jan 18, 2023 at 2:37 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I have been using the Permatex Silicone Ceramic Extreme Brake Lube #80653 (orange color) for all brake lube points. It is good for the rubber/plastic parts and metal to metal. Very wide temp range -50F to 3000F vs Sil-Glide range of -20F to 400F. Permatex Ceramic Extreme Brake Lube #24125 (purple color) not appropriate for rubber/plastic parts - causes swelling.
    WILLINH and Rocko9999[OP] like this.
  7. Jan 18, 2023 at 2:38 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I use nada.
  8. Jan 18, 2023 at 2:52 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    This
  9. Jan 18, 2023 at 3:13 PM
    2mchfun
    What good is 3000f grease? The other components and the fluid can't possibly get anywhere close to that without failure. Just can't see the why here.
  10. Jan 18, 2023 at 3:21 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    The 3000F is not the point - it's the 400F (or maybe 500F) of the Sil-Glide. Too low for metal to metal parts on brakes that can get very hot. Conventional wisdom has been to use two lubes, one for the rubber contacting pins (Sil-Glide is a favorite and works very well) and a copper or nickel based anti-seize (or the purple Permatex) for the metal to metal. The orange Permatex is relatively new and can work in all applications. I use it instead of the two different lubes just to keep things easy.
  11. Jan 18, 2023 at 3:25 PM
    2mchfun
    Maybe 400 coming down a mountain, not regularly. If so, time for driving lessons.
    Retired...finally likes this.
  12. Jan 18, 2023 at 3:33 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    3M silicon paste because I got it on sale a few years ago
  13. Jan 18, 2023 at 4:50 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Permatex purple goo on the pad ears and where the pad rubs on the caliper piston.
    Silicone paste on the slide pins
  14. Jan 18, 2023 at 9:01 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
  15. Jan 19, 2023 at 6:02 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I am replacing the calipers on my boat trailer. I thought about greasing the slide pins since I will I have them out. I am not planning to replace the caliber brackets. Not sure I can even get the bolts off the axle brackets. My thought is grease will attract dirt.
  16. Jan 19, 2023 at 8:35 AM
    Rocko9999
    If you had no anti-seize or purple Permatex and had to just buy one, would it be an anti-seize as it may have more purposes that just brakes?
    nobodyintexas likes this.
  17. Jan 19, 2023 at 5:30 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    Likely yes. I have an 8oz bottle of anti-seize that I have had forever - a little bit goes a long way. I do not have any purple Permatex, just the orange.
  18. Jan 19, 2023 at 5:31 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Use dry lube like graphite or dry silicone.
  19. Jan 20, 2023 at 1:06 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
