Brakes going to the floor
Discussion in 'New Member Introductions' started by Shaun7711, May 27, 2023.
  1. May 27, 2023 at 12:05 PM
    Shaun7711
    Shaun7711 [OP] New Member
    Shaun
    2007 Toyota Tundra
    Bed liner painted truck
    I have a 2007 Toyota Tundra 4.7L. My brakes are going to the floor when first start up and I have to pump the pedal several times while driving to build enough pressure to stop. No leaks, reservoir full, pads are all good. I would appreciate any help possible.
  2. May 27, 2023 at 12:09 PM
    Air in the system and a bad brake booster will cause that.
    tyr0981 likes this.
  3. May 29, 2023 at 4:51 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    ^^^Yep^^^
  4. May 29, 2023 at 5:44 AM
    Welcome from NY.
    Definitely air in the lines. You need to bleed them, if that doesn't work time to replace the booster.
    NewImprovedRon likes this.
  5. May 30, 2023 at 4:37 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Start with a good brake bleed.
  6. May 30, 2023 at 5:24 PM
    shamrock246
    shamrock246 New Member
    Vero beach
    I’ve seen this before on other sites where the booster caused a soft pedal. Is something specific in these boosters that fails and causes this? In the past when a booster went bad I’ve just lost power assist (firm pedal)or vacuum leak. I’ve been chasing a soft pedal for a while.
  7. May 31, 2023 at 3:52 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
