Brakes and Rotors
Discussion in '2nd Gen Tundras (2007-2013)' started by Skywind, Mar 27, 2023.
  1. Mar 27, 2023 at 6:25 PM
    Skywind
    Skywind [OP] New Member
    Hello all,
    My 2011 has 73K miles on it now, it’s almost time to replace the brake pads and resurface the rotors or replace. I tow a lawn care trailer regularly. More stopping power over oem would be a plus but not required. What pads/rotors do you all use and recommend?
    Thanks!
  2. Mar 27, 2023 at 9:28 PM
    radiant_red
    radiant_red New Member
    B
  3. Mar 27, 2023 at 9:40 PM
    2mchfun
    Stoptech cryogenic treated slotted rotors and EBC yellow pads, no regrets. About $600 iirc. DIY
    vangstang and Skywind[OP] like this.
  4. Mar 27, 2023 at 10:24 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Stoptech Sport or 120 series Rotors
    120.44156
    126.44156SL
    126.44156SR
    Bosch or Akebono Ceramic pads
    BC1303
    ASP1303
    coldcanuk, Neo258 and Skywind[OP] like this.
  5. Mar 28, 2023 at 1:50 AM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    I’ve used Autozone pads/rotors, OEM and high speed cryo’d, slotted stuff from stoptech w/ anti-judder “towing” pads.
    I drive normal and tow 4500-5000k lbs occasionally.
    Some dusted more than others. All lasted/performed about the same. You do you, but lot of snake oil out there in the brakes world. :thumbsup:
    Skywind[OP] likes this.
  6. Mar 28, 2023 at 7:09 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I simply ordered fresh Toyota stuff a couple years back when the system needed a refresh. Was a little over $400 for rotors, pads, and hardware kit for front and rear.
    They are still performing great, and I expect that to continue... Unless I stop using driving style to make things easier on my brakes. We do a lot of mountain driving, so using the correct gear helps a ton.
    WILLINH and Skywind[OP] like this.
  7. Mar 28, 2023 at 7:38 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Just like tires, choices in brake pads have a trade-off between grip and longevity. Really grippy pads (EBC, stoptech, etc.) produce more braking force, but these pads wear down themselves and your rotors much more quickly because they're much more abrasive. If you add slotted and/or cross-drilled rotors to the mix you increase brake performance further, but also further decrease your pad and rotor service life. I installed a stoptech pad and slotted rotor kit that needed new rotors with every 2nd pad change which occurred twice as often as my wife's van with OEM rotors and pads.
    If original braking performance meets your needs then keep your OEM rotors and use Thermoquiet brake pads. They provide reliable brake performance with excellent service life. They're also very easy on your rotors so you don't have to have them replaced or resurfaced when you do change the pads.
  8. Mar 28, 2023 at 8:26 PM
    Skywind
    I appreciate everyone’s suggestions and input!!
    2mchfun likes this.
  9. Mar 29, 2023 at 8:02 AM
    Monkey2583
    Monkey2583 New Member
    08 silver Tundra crew max 5.7
    Just led taillights and smoked headlights
    My 08 CM came with drilled and slotted and I bought it and went up north to move my mom down south . The brakes worked beyond anything oem would have done I've looked at power stop when I'm due to replace . I'll be looking about 500 rotors and pads .
  10. Mar 29, 2023 at 8:13 PM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    I installed this kit 2 years ago on mine. I tow a 26' travel trailer, and this kit does the job very well! Since you tow, you might consider it.
    https://www.amazon.com/gp/product/B00GNBGNBA?ie=UTF8
  11. Mar 29, 2023 at 9:31 PM
    SnowB0und
    SnowB0und New Member
    2013 SR5
    I used Advics from rock auto, identical to the OEM ones that came off of the truck for way less than dealer pricing. I reused the factory shims though, the aftermarket shims that came with the Advics seemed like junk (I used them on the rear, the squeaked). I just did a little write up on this on my site.
    Here's the part numbers:
    • Advics AD1303 - Front Brake Pads
    • Advics AD1304 - Rear Brake Pads
    • Advics A6F048 - Front Rotor X2
    • Advics A6R049 - Rear Rotor X2
    WILLINH likes this.
  12. Mar 30, 2023 at 12:39 PM
    CMikeB
    CMikeB New Member
    You mean....you use "S" MODE!!:eek::devil:
  13. Mar 31, 2023 at 11:20 AM
    COTundie
    Trey
    Pretty things
    Sporty AF
  14. Mar 31, 2023 at 11:49 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    Just remember to check your calipers. I had to rebuild them due to one boot was completely torn. I think I paid like 14 bucks for the rebuild kit from Toyota, and it came with the grease and everything you needed to do them. It's not a hard job and if you can change the pads you can rebuild the calipers.
  15. May 20, 2023 at 1:30 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    i read a couple accounts about the holes & slots in drilled & slotted rotors filling with dust/dirt/rocks et cetera when wheeling and wearing out brake pads faster than usual. think there's any truth to this? we head out to the dirt roads of the southern california deserts at least once a month, sometimes there's mud after rains. what are your thoughts?
    i've always stuck to centric premium rotors and hawk hp5 (i think) pads and have had good luck. but i carry a bit more weight in my tundra with 35s these days especially on camping trips like everyone else and their mother on instagram and would like a little more power over that setup. it's time for new brakes...
  16. May 20, 2023 at 3:07 PM
    Rodtheviking
    Vancouver, WA
    Sequoia
    I run Centric Premium rotors and Bosch Quietcast ceramic pads they feel much better than stock. However, I noticed the biggest improvement with Stoptech steel lines and fresh fluid.
  17. May 20, 2023 at 9:46 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    somebody else recommended stop tech too. and EBC. i just feel like my truck is HEAVY. i carry shit in the back all the time, have these big, dumb, heavy 35s that take more to stop. i need good brakes.
  18. May 20, 2023 at 11:10 PM
    Rodtheviking
    Vancouver, WA
    Sequoia
  19. May 21, 2023 at 12:57 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    Red calipers? Hard pass. And I don’t really feel like machining tabs or doing any extra work
  20. May 21, 2023 at 6:16 PM
    Rodtheviking
    Vancouver, WA
    Sequoia
    Then I guess you are on your own.
  21. May 21, 2023 at 10:08 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    alrighty then
  22. May 27, 2023 at 5:12 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Do you have part numbers for the rotors you used?
  23. May 27, 2023 at 7:06 AM
    2mchfun
    Tire rack apparently didn't list rear part numbers Screenshot_20230527-085735~2.jpg Screenshot_20230527-085848~2.jpg
    Tundrastruck91 and DZ_[QUOTED] like this.
  24. May 27, 2023 at 8:44 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Awesome, thanks, that's a start
    2mchfun likes this.
  25. May 27, 2023 at 11:21 AM
    2mchfun
    Not installed yet, but.... they are on the pile of upcoming modsIMG_20230527_131903205.jpg
  26. May 27, 2023 at 11:23 AM
    Aren't these supposed to increase the brake pressure?
  27. May 27, 2023 at 11:28 AM
    2mchfun
    They will minimize loss of pressure that occurs when the factory lines expand under pressure. Not much, but I like tinkering and it could be just enough when it really counts. That and I keep vehicles for decades, so....
    Tundra234[QUOTED] likes this.
  28. May 28, 2023 at 3:31 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    These look like a good option, from auto anything.
    Now to decide on pads... OEM TRD or EBC Yellow or ____?
  29. May 29, 2023 at 4:50 PM
    CTB Mike
    Southern Arizona
    I dunno...This looks oval to me! :devil:
  30. May 29, 2023 at 5:16 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    You're supposed to tilt your phone back when looking at the picture
