BRAKE!
Discussion in '2.5 Gen Tundras (2014-2021)' started by MJ_19Tundra, Dec 27, 2018.
  1. Dec 27, 2018 at 3:10 PM
    MJ_19Tundra
    MJ_19Tundra [OP] Ain't nuthin but a G thang
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    I drive a 2019 tundra TRD crewmax. It's happened a few times and I cant find out what it means. Between the RPMs and the speedometer it is a big solid red square and says BRAKE! in the middle. Truck has 400 miles on it. It comes on then goes right off. It has only happened 2 or 3 times and it is when I'm cruising around 45 mph. Nothing other than that happens when it comes on.
    Someone help me!!!
    Thanks
  2. Dec 27, 2018 at 3:12 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    That's the forward collision warning system.
    The sensor thinks you're about to hit something and is telling you to brake. Take it back to the dealer and they should be able to fix it; a few other members on here have complained of a similar issue.
  3. Dec 27, 2018 at 4:49 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Ct
    MJ_19Tundra[OP] likes this.
  4. Dec 27, 2018 at 5:30 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    typically the false alarms I've seen are when the road is poorly marked and significantly curves or climbs up/down, so if it's normal driving on a well-marked road you might want to have it looked at/calibrated
  5. Dec 27, 2018 at 6:16 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Mine did it today for about 3 seconds then stopped
  6. Dec 27, 2018 at 6:17 PM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Big read square middle of the screen says BRAKE!
  7. Dec 27, 2018 at 6:20 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    And beeped !
  8. Dec 27, 2018 at 6:24 PM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Yep that's it! Comes on and goes off. Mine was once at night and the other daytime. Idk what the hell it is and I cant find anything in the manual that shows the same thing that I seen....
  9. Dec 27, 2018 at 6:27 PM
    ninjajay
    Spoolston, TX
    page 232 on the 2018, 231 on the 2019
  10. Dec 27, 2018 at 6:46 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Yeah I know it’s hat it is I adjusted the sensitivity so we will see
  11. Dec 28, 2018 at 2:49 AM
    rsgt
    rsgt New Member
    2019 crew cab TRD sport 4x4
    all stock
    Mine comes on only when I'm approaching a vehicle in front of me when it senses I'm to close and I didn't apply the brake. Love it Never had false warnings
  12. Dec 28, 2018 at 3:58 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I get the false brake when I come up on curves when there is traffic.
  13. Dec 28, 2018 at 5:06 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona. As others have mentioned, the warning being displayed is generated by the pre collision system. The system thinks that the truck needs to brake in order to avoid a collision. If you're getting the warnings on a straight road with no other traffic around, your system may need to be updated with either a software update or a sensor replacement. Several of the members on here have experienced problems that needed to be corrected by the dealership. The sensitivity of the system is user adjustable and the owners manual also advises to turn the system off during certain types of road and driving conditions.
    NewImprovedRon likes this.
  14. Dec 28, 2018 at 7:41 AM
    lamikela1
    lamikela1 New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    You should only see this if the PCS detects that you are approaching an object too fast and there is an eminent collision about to happen. If you are under a certain speed the PCS will apply the brakes and bring the vehicle to a complete stop. If over a certain speed it will only display the warning so that you can apply the brakes. I don't recall exactly but the speed is somewhere between 20 and 30 MPH.
  15. Dec 28, 2018 at 7:58 AM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    If you leveled the truck (lifted it) it could be part of the problem and needs recalibration. A cool service writer / tech would do it under warranty. However if they notice it's been modified they can charge you for the labor/time to do it. Last I heard it can cost up to $250. So in that case, go in, complain it's been acting weird and play dumb.
  16. Dec 28, 2018 at 8:17 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I’ve only had two false alarms in 13000/8 mos. they were both in strange driving conditions, but with no vehicle in front of me, not even in the oncoming lane.
    It makes me wonder what the system is ‘taught’ to look for.
    Factory height/suspension (for now)
  17. Dec 28, 2018 at 3:46 PM
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    Give it a chance to learn. It will have a few false alarms for 4000 some miles. Also it could be your driving habits. I know when I’m rushing somewhere the brake alarm will come on.
  18. Dec 30, 2018 at 5:02 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Been lucky with mine. I'm at around 5k miles, owned it 5 months now; I've only had BRAKE come up once, and it was justified.
