Brake Whistle-like Noise
Discussion in '2nd Gen Tundras (2007-2013)' started by Hank, Sep 27, 2023.
  1. Sep 27, 2023 at 1:57 PM
    Hank
    Hank [OP] New Member
    2008 Tundra, 5.7, Crewmax
    At slow speeds I get a whistle when I press the brake petal. I also get a whistle when I let off the brake petal. The noise seems to be coming from the front half of the truck, and best I can tell from the driver's seat is the noise is coming from under the truck.
    I suspect the noise is a vacuum leak of sorts and associated with the brake booster. I have not confirmed this.
    I've searched the best I can and cannot find a similar problem that also includes a final result. Any help is appreciated.
  2. Sep 27, 2023 at 2:02 PM
    Gonna have to get under the hood and check the brake booster vacuum line and booster. Brakes acting normally? Definitely a whistle and not a screech from low brake pad indicator?
  3. Sep 27, 2023 at 2:43 PM
    Hank
