Brake Upgrade items
Discussion in '1st Gen Tundras (2000-2006)' started by Jbhoops, Aug 13, 2022.
  1. Aug 13, 2022 at 2:19 PM
    Jbhoops
    Jbhoops [OP] New Member
    2001 tundra access cab
    Looking to go with the gx460 lexus upgrade. Just curious if you guys are buying oem calipers rotors and pads. Or a combo of oem calipers and aftermarket pads and rotors. All suggestions welcomed. Oh.also brake line recommendations.
  2. Aug 13, 2022 at 8:13 PM
    Jbhoops
  3. Aug 13, 2022 at 8:16 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Don't do it!
    txagg likes this.
  4. Aug 14, 2022 at 2:04 AM
    not so fast 2
    not so fast 2 New Member
    bob
    Whats the reason for change??
    Mine developed a shimming when braking hard or firmly, tried aftermarket pads to no avail. So I changed out the rotors and pads again and that solved it, no shimmy ever since, yippee
    Dont laugh but I got everything from AutoZone, yep AutoZone, Toyota was way high and it was their product that failed anyways lol
    Good luck
    NSF
  5. Aug 14, 2022 at 8:46 AM
    Jbhoops
    I was driving down a mountain and had to follow a dump truck. Brakes were cooked by the time I got down to the bottom with serious fading going on. What about that Z package upgrade forgot if it was z36 or z32.
  6. Aug 14, 2022 at 11:57 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Thats just the newer 03+ calipers that have larger pads and same sized rotors.
    Jack McCarthy likes this.
  7. Aug 15, 2022 at 1:25 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    @FirstGenVol Are you still having issues? I just did the GX460 brake upgrade and I really like it. The pedal feels like stock.
    OP, I bought these calipers (https://www.amazon.com/dp/B07DKKDNRR?ref=ppx_yo2ov_dt_b_product_details) and painted them gloss black. I then bought PowerStops kit (https://www.amazon.com/dp/B00O6QJSVQ?ref=ppx_yo2ov_dt_b_product_details). I aslo bought new stainless steel brake lines for the front and rear. I've very please with the upgrade. I did have the system flushed with new brake fluid too.
  8. Aug 15, 2022 at 2:16 PM
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    2006Tundra likes this.
  9. Aug 15, 2022 at 5:21 PM
    Jbhoops
    Thanks for.the info guys didn't understand why .my first few responses were don't do it????
  10. Aug 15, 2022 at 5:37 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I've had a nightmare with mine but other people haven't had any issues. Sorry to not give a more helpful answer before.
    I bought my calipers from Rock Auto and had a machine shop mill the ears for me. Installed them myself.
  11. Apr 16, 2023 at 9:35 AM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
    What was the nightmare? I’m looking at doing the same thing myself after 3 sets of rotors and pads
  12. Apr 16, 2023 at 9:35 AM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
    You guys that have done the swap how are you liking it?
  13. Apr 18, 2023 at 8:15 AM
    2005 DC 4x4
    Absolutely LOVE it. In hindsight, I consider it mandatory on these old trucks. As a somewhat aggressive driver, it has legit saved me a few times.
  14. Apr 18, 2023 at 9:35 AM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
    Awesome. My calipers are on the way to Jim right now
  15. Apr 18, 2023 at 11:17 AM
    2006Tundra
    Lou
    Long Beach, CA
    I love it on my 06 DC. No issues for me.
  16. Apr 18, 2023 at 3:48 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    It seems like the DC's and Sequoia handle the upgrade the best without needing a different MC
    2006Tundra[QUOTED] likes this.
  17. Apr 18, 2023 at 6:04 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Just out of curiosity for those of you with dc’s @912 @2006Tundra @rock climber yall got the normal MC or the stupid expensive with vsc?
    I’d love to do this but like a dumb*** bought 16 inch wheels. So more or less info gathering at this point
  18. Apr 18, 2023 at 6:23 PM
    Which wheels did you pick up? Just curious. As soon as the wheels I'm eyeballing are available, I'm dropping some coin and will be offloading my OEMs.
    Cummins3500[QUOTED] likes this.
  19. Apr 18, 2023 at 7:44 PM
    Cummins3500
    Logan
    Method 304 double standards, I’ve had em for awhile, should’ve went 17s when I swapped to em. At the time I hadn’t really looked into the big brake upgrade and figured it wouldnt be something I’d ever want or need.
    shifty`[QUOTED] likes this.
  20. Apr 19, 2023 at 6:31 AM
    2006Tundra
    Lou
    Long Beach, CA
    I'm still using the stock MC. The pedal feels solid, and the stopping power is nice. I also went for braided SS lines (front and rear) and had a 100% brake fluid exchange.
    You may be able to use 16" wheels. If my memory is correct, when I was doing the BBK, for shits and giggles, I put my 2004 Tacoma spare (16") on the 06 DC, and it cleared the GX460 caliper. I'll need to confirm. If I have some time after work today, I'll swap wheels.
  21. Apr 19, 2023 at 7:01 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    As long as Jim does your calipers you shouldn't have the same headache I did. I used a local machine shop. I have no clue what went wrong with mine but I never could get rid of mushy pedal. I would have to double pump to prime them. Two years of trying everything I could to make them work before giving up. As soon as I removed them and went back down to stock size calipers it was fine.
    I was also having a horrible rattle that went away when I pressed the brakes. That's how I finally realized the calipers were FUBAR'd. They were rattling against the spindle where they bolt up.
    No more rattle with the new calipers.
  22. Apr 19, 2023 at 9:54 AM
    rock climber
    Luckily, I have the normal one.
  23. Apr 19, 2023 at 10:05 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    @Cummins3500
    My DC Sport Trac has the normal MC and can only hope it hangs in there for awhile.
    Cummins3500 likes this.
  24. Apr 20, 2023 at 12:51 PM
    912
    2005 DC 4x4
    I'm fortunate to also have the normal MC and still running the original. Added stainless lines when I did the upgrade.
  25. Apr 21, 2023 at 4:07 PM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
    That’s sucks. I actually thought about having a local machine shop mill them, but I kinda figured it would ne starting from scratch from them. Buy once cry once. I’m gonna replace my rear shoes as well as all 3 rubber brake lines. Fingers crossed no mushyness. Eventually I’m gonna do the T-100 Mc upgrade as well. But the boat trailer needs brakes first.
  26. Apr 22, 2023 at 5:27 PM
    2006Tundra
    Lou
    Long Beach, CA
    Keep us posted. I'd like to hear your feedback.
  27. May 18, 2023 at 5:23 PM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
    Will do
  28. May 30, 2023 at 8:49 PM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
    Big brake upgrade is completed. Not gonna say it’s a “massive improvement” but most definitely better than the stock set up. To be fair I did new shoes out back, as well as steel braided lines front and rear. All at the same time Tried using my neighbors bleeder but couldn’t get it to work. So had the warden pump brakes for me One thought. Get the banjo bolts from Chase bays. I bought 4 different. Bolts of the same size they were the only ones I could get to snug down. Also wheelers steel brake lines were used All in all Im happy. I’ll probably do the t-100 master cylinder / booster upgrade later
  29. Jun 1, 2023 at 6:08 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    So where did you end up buying the calipers from? And the mushy pedal feeling?
  30. Jun 1, 2023 at 7:56 AM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
    I got calipers from Jim smola. He’s on Facebook tundra pages. I don’t think they are mushy. Bought the same feel as before replacing. Just better stopping power I may do the t-100 upgrade in the future. But for now they work. Next is raptor lining the shell and front bumper
