Brake troubles
Discussion in '1st Gen Tundras (2000-2006)' started by Justins?, Jul 26, 2023.
  1. Jul 26, 2023 at 10:48 AM
    Justins?
    Justins? [OP] New Member
    Justin
    2000 Tundra sr5
    Hello I have a 2000 sr5 tundra I bought the only issue was the brakes needed bleed
    I did multiple times in my petal gose to the floor I looked for leaks without luck so I took the tires off in the rear hubs off to expose the wheel cylinders in found a small leak so I replaced both of them then Continue to Bleed them yet again the Pedal goes to the floor I replaced the master cylinde Before installing i Bench blood the master cylinder I left the brake lines loose Up top to Bleed them from. After all this, I've still have no Breaks any help would be appreciated.
  2. Jul 26, 2023 at 10:53 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Did you bleed the prop valve near the spare tire?
    shifty` and Jack McCarthy like this.
  3. Jul 26, 2023 at 10:57 AM
    Justins?
    Justin
    2000 Tundra sr5
    Dose it sit high above the rear axel driver side rear tire ? If so yes
  4. Jul 26, 2023 at 12:25 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    In the right order? I believe it's RR, LSPV, LR, RF, LF
    shifty` likes this.
  5. Jul 26, 2023 at 12:40 PM
    shifty` Bohannon Bohannon Bohannon Bohannon
    I wonder if someone blew out seals by shoving the pedal all the floor?
  6. Jul 26, 2023 at 1:06 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Yup, always put a spacer under the pedal when bleeding.
  7. Jul 26, 2023 at 1:16 PM
    Justins?
    Justin
    2000 Tundra sr5
    Wasn't like hard pressed just zero Resistance ... I guess you would say you put your foot on it and it falls Sort of speak.
  8. Jul 26, 2023 at 2:20 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    What happens if you push it with the engine off?
    shifty` likes this.
  9. Jul 26, 2023 at 2:32 PM
    And, bear with me, how did you bleed the brakes. Like ...
    Did you use positive pressure on the reservoir (powerbleeding)?
    Was the truck running while bleeding?
    What order did you bleed in, exact order of wheels?
    Did you bleed the LSPV (brake prop valve) also, since that's pretty damn important?
    Beyond that,
    Are you 100% positive you have no leaks at a bleeders or any other line?
  10. Jul 26, 2023 at 8:58 PM
    Justins?
    Justin
    2000 Tundra sr5
    Okay, just thought i'd given update. Not a hundred percent sure what is going on Got in from work. Did the usual win inside with my family for a while, Yada Yada.
    Anyways went out to my truck, looked at the LSP v just to see if there was any leaks, it's around, did not See anything. So went to start my vehicle batteries Is dead go figure Anyways after jumping the battery Started my truck, put it in drive and my brake pedal work. Try to no reverse again my break that worked granted i'm only Moving in my driveway so short distances, but it's stopping before it was doing anything so now that it's later and less traffic is out. I guess I'm gonna drive it up the street. That way I can get more speed going and see what kind of pedal I have But I have not done nothing since yesterday. When I bled them and had absolutely no luck. 0 pedal for some reason After I got off work today in the driveway at At least now I have some type of pedal just not sure where it came from or how long it will stay ‍♂️
  11. Jul 27, 2023 at 4:03 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Try a few pumps of the pedal with the engine off. See what the pedal does.
