Brake squeal -dealer said…..
Discussion in '3rd Gen Tundras (2022+)' started by ansel123, Nov 23, 2024.
  1. Nov 23, 2024 at 8:11 AM
    ansel123
    ansel123 [OP] New Member
    Sr5 2024
    Several
    They are aware and ordered me new pads and parts——-back ordered for 4 months!!! For brake parts? Wtf
  2. Nov 23, 2024 at 8:19 AM
    lapoolboy
    lapoolboy New Member
    Yep, mine said "see you next year".
  3. Nov 23, 2024 at 8:37 AM
    Observer
    Observer New Member
    Makes you wonder if the pads are subcontracted to the same company that does the key fobs. :)
    jt13077 and Blufin like this.
  4. Nov 23, 2024 at 8:46 AM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    better to get them to acknowledge and order parts to repair than a sharp stick in the eye - aka "it normal" and move along.
    Breathing Borla likes this.
  5. Nov 23, 2024 at 2:19 PM
    sablue
    sablue New Member
    jay
    2022 tundra plat
    yup. I'm up to 6 months waiting on the parts. Already got the engine
  6. Nov 23, 2024 at 2:27 PM
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
    Finally tracked my guy down because he picked up the phone at the dealership. He said unless they mass produce it it’ll be months due to long list of vehicles needing it. What a load of crap
  7. Nov 23, 2024 at 2:34 PM
    ansel123
    Sr5 2024
    Several
    I find your lack of Faith disturbing… and justified lol
  8. Nov 23, 2024 at 2:43 PM
    Gepperso
    Gepperso New Member
    Greg
    Georgia
    2022 1794 Smoked Mesquite
    Talon Garage Catt Shield, 2 K&N Air Filters, Thorton Chip Tuning
    My Dealership said that my part is still on back order, No ETA at this time.
  9. Nov 23, 2024 at 3:09 PM
    articdesert
    23 1794 MGM
    these corporations use all of their resources to get the most out of consumers while giving back the bare minimum. After buying so many bridges in this life, you start to see things from the trolls perspective
    Leo's first likes this.
  10. Nov 23, 2024 at 3:11 PM
    Ericsopa
    Ericsopa Old man and the sea
    Custom makin' them suckers by hand are they? :rolleyes:
  11. Nov 23, 2024 at 3:11 PM
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    The parts are not on back order per se. There are plenty of them out there in different warehouses. The main problem is Toyota has put these parts on a "MAC" release. Each dealership can only order 1 set of the TSB parts per week. It gets new rotor, pads, shim, fit kit, and brake caliper grease. So dealers have to order all those parts on the same order reference # and they only get a set of parts per week. So unless your dealer has tons of Tundras in need of this TSB it should only be taking a few days.
  12. Nov 23, 2024 at 3:15 PM
    articdesert
    23 1794 MGM
    My ‘22 got changed out from a different dealer about 1.5 months after I brought it up to them
  13. Nov 23, 2024 at 3:18 PM
    ansel123
    Sr5 2024
    Several
    My guy said hes been waiting four months for another customer before me…
  14. Nov 23, 2024 at 3:34 PM
    LionsFan20
    Josh
    24 Tundra
    Something does not sound right...
  15. Nov 23, 2024 at 3:49 PM
    ansel123
    Sr5 2024
    Several
    You’re right, its my brakes in reverse lol
  16. Nov 24, 2024 at 9:33 AM
    Rockpig
    Rockpig You did what?
    08 Limited
    So what is different with the new parts that everyone is waiting for?
  17. Nov 24, 2024 at 9:35 AM
    ansel123
    Sr5 2024
    Several
    That’s my thought since when are brake parts so difficult to attain
  18. Nov 24, 2024 at 10:22 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Took my dealer 10 days to get the parts in once they ordered them.
  19. Nov 24, 2024 at 11:26 AM
    articdesert
    23 1794 MGM
    these brakes are semi metallic asphalt terrain, durably used in variably performance environments
  20. Nov 25, 2024 at 5:25 AM
    ansel123
    Sr5 2024
    Several
    Was that this year?
  21. Nov 25, 2024 at 5:43 AM
    sudobash
    sudobash New Member
    Yes.
    Different areas of the country have different warehouses. They also have different demands when it comes to particular parts.
    The brake squeal has been an issue since the 3rd Gen was introduced, so there were a lot of owners waiting for a resolution to this. They also just expanded the brake squeal issue to the LX600 and GX550. I would assume that the Land Cruiser is next because owners are complaining about it as well.
    Tundrastruck91 likes this.
  22. Nov 25, 2024 at 6:12 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    It was about 3-4 weeks ago, new parts have been in for 10 days. Happy to report no brake noise since the change.
    As sudobash posted , I guess some dealers have better resources for parts.
  23. Nov 25, 2024 at 7:00 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    When I had mine in for its 5K I mentioned it and since they couldn't reproduce the squeal at the time, they wouldn't order parts. So, basically I'm a liar.
    Will do it every. single. time. when it's cold. (After sitting overnight; not dependant on ambient temperature.)
    They wanted me to make a separate service appointment just so they could "evaluate" and hopefully order parts. And back a third time after that to install.
    My closest dealer is 40 minutes away.
    I just avoid backing up when it's cold now.
  24. Nov 25, 2024 at 7:26 AM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
    If a vehicle that is covered by the state’s lemon law is not repaired within a reasonable time, the owner is entitled to a refund, replacement vehicle, or cash compensation. Therefore, the owner of a new vehicle that has been sitting in their driveway or the repair shop waiting for a replacement part may be legally entitled to demand a full refund or replacement vehicle.
    I would go back to the dealership and repeat verbatim and say because brakes are a safety system you would like a loaner vehicle for the duration of the repair.
