Brake shields
Discussion in '1st Gen Tundras (2000-2006)' started by RR60, Jun 19, 2020.
  1. Jun 19, 2020 at 10:01 PM
    RR60
    RR60 [OP] New Member
    2003 SR5 Tundra long bed
    Any idea on what is a fair labor charge for this.
    2003 Tundra. Front brake dust shields are in bad shape from rust.
    One even has a small section missing.
    Wished they had mentioned it when I had the calipers replaced a 1 1/2 years ago. And maybe saved some labor.
    Thanks for any guess.
    Also if any suggestions if there is a aftermarket one.
  2. Jun 20, 2020 at 3:54 AM
    Bubbadog
    Bubbadog New Member
    One of mine rusted away and I never bothered to replace it.
    Do you even need it?
    2006Tundra likes this.
  3. Jun 20, 2020 at 5:11 AM
    Adam New Member
  4. Jun 20, 2020 at 5:40 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'd save it for when you have to do the wheel bearings, or go ahead and do them. You have to remove the whole spindle and press the hub out to get to them.
  5. Jun 20, 2020 at 6:30 AM
    RR60
    Older truck and trying to keep it looking new. So dont like to see something rusted out. Just looks bad. Not sure if I need.
    Sounds like a good plan with the wheel bearings so not paying for labor again.
    Can you guess what is the average for when you need to replace the wheel bearings? Will I definitely need to?
    Mine has just turned 100K. Only put 4 to 5K a year. And will keep at least another 10 years. Whatever it takes. Unless they go back to making this model.
  6. Jun 20, 2020 at 6:56 AM
    Professional Hand Model
    Hand Protectors
    I’d leave it alone until/if you ever have a problem with bearings. For anyone else, yours can be restored back to looking like these.
    bmf4069, MTRock, jtwags and 1 other person like this.
  7. Jun 20, 2020 at 9:27 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    In the process of rebuilding my suspension, I found the brake shields on both sides badly rusted away. I removed The remnants and the only replacements I could find are OEM at the cost of $80 per side. I just couldn’t justify that kind of outlay for a piece of stamped steel.
    I thought about making a couple of shields to replicate the originals, but I’m not at that point yet. Or, I’ll just go without them
  8. Jun 20, 2020 at 10:18 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Why replace them? I ripped mine out when I did the Tundra brake upgrade on my LT Tacoma. I have zero issues.
    Geo4x4, Darkness, N84434 and 2 others like this.
  9. Jun 20, 2020 at 12:08 PM
    fighthedude
    fighthedude New Member
    Bad ass looking suspension. You have a build tread to look at all that work? Sorry to hijack
    2006Tundra[QUOTED] likes this.
  10. Jun 20, 2020 at 12:11 PM
    2006Tundra
    Lou
    Long Beach, CA
    Thanks. Yeah, check out the links below.
    N84434 likes this.
  11. Aug 31, 2020 at 1:20 PM
    Brendanimals
    Brendanimals New Member
    Brendan
    York, PA
    2006 Tundra Double Cab SR5
    Eibach Pro Truck Sport Leveling Shocks - 3" 2.5" Blocks plus Sumo Springs (blue) in the back Nitto Terra Grappler G2 265/70/r17's K&N 57-9027 Cold Air Intake N-Fab Black Wheel To Wheel Nerf Bars Addco 2181 Rear Anti-Sway Bar
    Does anyone have an opinion on how necessary dust shields are? I'm in the same boat - terribly rusted to shreds and I feel like $160 bucks for a set of thin stamped metal brackets is too much.
  12. Aug 31, 2020 at 1:25 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If mine were in bad shape I would cut them off.
  13. Aug 31, 2020 at 1:33 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I've heard mixed things about them. I cut my old ones off my old 4runner because of rust and didn't have any issues (driving through snow, mud, water, dirt) but I could see how you run the risk of getting more debris (mud, rocks, etc) hitting your calipers and rotors. Might also make your brakes squeak a bit more until cleaned.
    I think I remember someone suggesting to cut keyhole in the brake shield so you can get it around the spindle and hub and then bolt on as normal or possible throwing small metal strap on top to hold them together better once on. No need for pressing a hub in and out. Doesn't help with the $80 shield though.
  14. Aug 31, 2020 at 3:19 PM
    Hand Protectors
    They are there for a reason. I’d replace them, but your call.
    Tundra2 likes this.
