Brake Rotor Upsizing
Discussion in '3rd Gen Tundras (2022+)' started by Just_Tito, Jul 7, 2025.
  1. Jul 7, 2025 at 9:29 PM
    Just_Tito
    Just_Tito [OP] New Member
    23 Tundra
    My Porsche Cayenne Brembo brakes for my Audi came with 6pt calipers and 365mm rotors. I was able to upsize them to 380mm with just an adapter. Does anyone know if we can do this with these Toyota calipers?
  2. Jul 8, 2025 at 3:28 AM
    nodak67
    nodak67 New Member
    JR
    could try r1 concepts, but i think i can count on 1 hand the number of people that have done that.
  3. Jul 8, 2025 at 5:45 AM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    The only kits I've seen are full BBKs... I don't believe there is a larger OEM rotor that uses the same caliper on anything
  4. Jul 8, 2025 at 8:44 AM
    Just_Tito
    23 Tundra
    I gotta find the manufacturer of the calipers. With Porsche, Brembo makes the rotors and calipers.
  5. Jul 8, 2025 at 8:56 AM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    Are you feeling fade in your current application? A minimally larger rotor may slightly increase brake torque, but nothing leading to a big change... Something along the lines of a 15mm increase in rotor diameter will yield a very minimal torque advantage (even 25mm+ increase in rotor size doesn't yield a huge difference while retaining a non-performance caliper).
    You'd feel a bigger difference in fade resistance and torque by switching to a different pad compound.
    I'm not sure who makes the 3rd gen brakes, but as per another thread on here the 2nd/2.5 gen brakes OEM supplier was Advics; so that may be somewhere for you to start.
    If you want a legitimate upgrade in stopping power, I would suggest looking into full BBK's from either PowerBrake or Alcon
  6. Jul 8, 2025 at 11:37 AM
    Just_Tito
    23 Tundra
    Brakes are fine, purely aesthetics. I just bought 24s that will make the brakes look small.
  7. Jul 8, 2025 at 4:02 PM
    Frank_TRD23
    Frank_TRD23 New Member
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    The Hybrid brake don't help either if there was an upgrade size. I'd you have a hybrid.
    Stop pressing the brakes with only your big toe. Using your whole foot makes a difference in stopping.
