Brake Rotor & Pad recommendation
Discussion in '2.5 Gen Tundras (2014-2021)' started by saadi996tt, Oct 5, 2017.
  1. Oct 5, 2017 at 10:44 AM
    saadi996tt
    saadi996tt [OP] New Member
    Saadi
    Bakersfield, CA
    2014 CM LTD
    Limo Tint (all around), Weather Tech Floor Mats, Morimoto XB LED Fog Lights, Nerf Bars, Paragon Bed cover (Paint to match), Bilstein 6112’s (F) & 5100’s (R), Wireless iPhone charger, TRD rear sway bar, swing case, led bed lights, pop-n-lock...
    Hey All,
    Can anyone recommend a good rotor pad package for 2014 CM 2wd? I upgraded the shocks yesterday Bilstein 6112 front, 5100 rear, along with some new tires Nokian Rotiva AT 275/60/20.
    Need to change out the pads ASAP since there isn’t too much meat left on the bone. That and these rotors feel like they are warped so might as well change them all at once.
    Any advise would be appreciated.
    Thanks, Saadi
    rebelyell1191 likes this.
  2. Oct 5, 2017 at 10:48 AM
    Centric premium Rotors and your choice of pads. EBC, Hawk, Centric premium ceramic pads, good parts store brands.
    Follow the bedding in process and you should be good to go.
  3. Oct 5, 2017 at 10:59 AM
    TheBeast The Beach
    I switched to Stop Tech Sport slotted rotors and Posi Quiet ceramic pads. Very happy with them.
    autoanything carries them.
    Prostar 190 likes this.
  4. Oct 5, 2017 at 11:04 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    Bought oem Toyota Tundra rotors off eBay for $69.00 for pair. Previous owner got 90k with originals. Seemed like a no brainer. Good luck. D
    Patriot, netranger6 and blizz86 like this.
  5. Dec 28, 2017 at 7:38 PM
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    Just ordered the SP's sounds like a good rotor.. thanks
    GNTundra likes this.
  6. Jan 2, 2018 at 11:07 AM
    TheBeast The Beach
    stop tech power sport for rotors
    GNTundra and ColoradoTJ like this.
  7. Jan 13, 2018 at 4:33 PM
    Boxer13
    Boxer13 New Member
    2016 Crewmax Trd
    3/1 lift with add leaf pack 275/70/18 BFG kO2 K & N filter Rock sliders Hawk brake pads Hula girl on dash
    I highly recommend Hawk LTS brake pads, noticeable difference even with the stock rotors. Follow the bedding in process and your go to good.
    ColoradoTJ likes this.
  8. Jan 13, 2018 at 8:01 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    I have no probs with stock rotors and pads
  9. Apr 29, 2018 at 10:11 PM
    saadi996tt
    Saadi
    Bakersfield, CA
    2014 CM LTD
    Hey all, I just changed my rotors and pads today. I decided to go with the Stop tech rotors and pads. The install went smoothly but when I took it out for a drive to bed the pads and rotors things didn’t go as smoothly. The truck takes forever to stop and the pedal feels all spongy to the point where the brake pedal is all the way to the floor. I can feel the abs working but it just doesn’t feel right.
    I didn’t bleed the brakes because I didn’t disconnect any of the brake lines. Could air have gotten in when I was pushing the pistons back to make room for the new thick pads?
    Any advise would be greatly appreciated...
    Thanks,
    Saadi
  10. Apr 29, 2018 at 10:18 PM
    It takes a few good heat cycles to bed those rotors and pads. I think mine took three times.
    Always bleed the brakes a bit. This ensures good pedal feel.
    I also don’t recommend pushing fluid back through the system via the caliper pistons. When collapsing the pistons, I crack open the bleeder and then release the pressure locally.
  11. Apr 29, 2018 at 10:24 PM
    saadi996tt
    Saadi
    Bakersfield, CA
    2014 CM LTD
    I didn’t bleed the caliper while pushing the piston back. Should I bleed all 4 corners and see if it helps? I have a motive power bleeder I use on my 911 when I upgraded the brakes.
  12. Apr 29, 2018 at 10:28 PM
    That is exactly what I would do.
  13. Apr 29, 2018 at 10:35 PM
    saadi996tt
    Saadi
    Bakersfield, CA
    2014 CM LTD
    I’ll try it tomorrow and post my results.
  14. May 4, 2018 at 1:31 AM
    Any updates on this issue?
  15. May 4, 2018 at 7:25 AM
    saadi996tt
    Saadi
    Bakersfield, CA
    2014 CM LTD
    Sorry fellas, I’ve been swamped at work, I’m going to bleed the brakes tonight after work and post my results. Needed to buy an adapter for the Motive power bleeder for the tundra. Will post pics too once I’m done tonight.
  16. May 6, 2018 at 4:32 PM
    saadi996tt
    Saadi
    Bakersfield, CA
    2014 CM LTD
    Hey all, I bled the brakes last night and as Chris recommended the tundra is braking much better than it did before I did the upgrade. I also noticed that after I bedded in the brakes it took roughly another 2 days for the spongy fleeing to go away. Maybe the bedding in procedure needs to be followed a few times.
  17. May 6, 2018 at 5:09 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
