Brake Recommendation
Discussion in 'General Tundra Discussion' started by aggietundra2021, Oct 31, 2021.
  1. Oct 31, 2021 at 3:24 PM
    aggietundra2021
    aggietundra2021 [OP] New Member
    Ryan
    2016 Toyota Tundra
    None
    Recently purchased a 2016 Tundra and I need to replace to rotors and pads. I plan to use OEM parts. Do you have any recommendations for other brands?
  2. Nov 5, 2021 at 8:44 AM
    2mchfun
    Welcome to the forum! When I get around to it, mine will be swapped to EBC yellow stuff pads. Just my .02!
  3. Nov 5, 2021 at 9:24 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Ryan, you can use search in upper right to find threads with whatever you are researching, super easy and works well. Stock stuff is decent. Some prefer aftermarket for more aggressive pads. Tundras seem to be hard on brakes, cryo treated rotors are also a popular upgrade.
    This will get you started
    https://www.tundras.com/threads/what-brakes-pad-rotors.58537/
    https://www.tundras.com/threads/brake-pads-what-works-well.18574/
    https://www.tundras.com/threads/rotors-that-wont-warp.82606/
    https://www.tundras.com/threads/brakes-and-rotors.92960/#post-2361062
    https://www.tundras.com/threads/lets-talk-about-rotors-and-pads.90254/#post-2336409
    scjb007 likes this.
  4. Nov 5, 2021 at 10:06 AM
    Limp Mode
    Limp Mode New Member
    Hawk LTS pads (more dust than stock if that's something you care about), StopTech Cryo treated rotors
    Until someone can give me a convincing reason that another solution is better, this is the best I've seen short of big brake kits.
  5. Dec 29, 2021 at 1:55 PM
    thumper_racer
    thumper_racer Not a New Member
    TN
    2012 MGM Rock Warrior
    +1 for this setup!
