Brake Problems with 2024 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by fedupwithtoyota, May 15, 2025 at 1:27 PM.
  1. May 15, 2025 at 1:27 PM
    fedupwithtoyota
    fedupwithtoyota [OP] New Member
    Yesterday
    I have 22,000 miles on my 2024 Tundra, I have had excessive vibration when braking. I noticed this problem started around the 10,000 mile mark. I have brought it to the dealer twice now. once at 15,000 miles and again at 20,000 miles. They say the rotors are slightly out of specs and that they suggest I put new rotors and brakes on. I told them this should be a warranty issue. Toyota customer care says they will not cover the cost of the work. Has anyone else had these problems? Any success on getting Toyota to cover the costs?
  2. May 15, 2025 at 1:50 PM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    I had the exact same issue. They turned them and they have been fine since. I paid $380 for that and an oil change. Complete bullshit it was covered under warranty. Same week I took my BMW in with the same issue. No charge.
  3. May 15, 2025 at 2:03 PM
    Manutd818
    Manutd818 New Member
    2024 Tundra Limited Trd off-road
    That’s interesting. Literally just came back from the dealer, I was also feeling some shaking especially turning and riding the brakes. Called me back just now said the rotors are warped slightly and that they will replace them with new ones and new brake pads, no charge of course. I have about 11k miles. It is a warranty issue, I don’t understand how they can say it’s not.
    I also asked to check alignment, turned out I was right. Again, said we only cover alignment for the first year but I’ll go ahead and do it for no charge. I must’ve got real lucky, cuz I didn’t even wanna take it to this dealer near me. It’s a small dealer with not so much action, but I’m happy now.
  4. May 15, 2025 at 2:23 PM
    scs_vuth
    scs_vuth New Member
    Vuth
    Bay Area
    Brake rotor can warp when you don't let it cool down properly. You'll need to let it sit at least 30 mins or more before running it through a car wash or washing it at home. I usually let it sit for 1hr or more before washing.
    If you cannot hold your finger tip on the brake rotor for more than 3-5 seconds then it's still to hot for a wash.
    Splashing water running through a pot hole full of water can cause the brake rotor to warp also.
    Once you get the vibration, it's best to change out the rotor for a new set up. Turning the rotor is a temporary fix. Once the rotor reaches a hot heat cycle again, it will start to vibrate again.
  5. May 15, 2025 at 2:49 PM
    DRP
    DRP Old Member
    Dave
    I sure hope it doesn't rain the next time I need to use my brakes :thumbsup:
  6. May 15, 2025 at 4:02 PM
    Spartanfam
    Spartanfam New Member
    West Michigan
    2024 Tundra Limited TRD Off-Road
    Brake rotors on passenger cars and trucks rarely warp… or deform. The brakes shudder is actually from hot spots that can form with pads that transfer material into the surface of the rotors and causing inconsistent friction for braking.
    The term “warp” is a misnomer .
    DRP, sudobash and Leo's first like this.
  7. May 15, 2025 at 5:55 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    Have you ever turned the rotors yourself? Just curious:confused:
    Spartanfam[QUOTED] likes this.
  8. May 15, 2025 at 6:11 PM
    Josue914
    Josue914 New Member
    2000 Tundra Access Cab
    That really blows that they are trying to make you pay for them. I would recommend claiming that the front brakes are making a squeal noise and mention TSB-0022-25. In the tsb it has the technician replace the shim kit for updated ones and pads/rotors. This would take care of your vibration and would be covered under the 36 months 36k miles. but you didn't hear it from me
