Brake problem
Discussion in '2nd Gen Tundras (2007-2013)' started by Retired Teacher, Aug 14, 2022.
  1. Aug 14, 2022 at 8:57 AM
    Retired Teacher
    Retired Teacher [OP] New Member
    2007 White Tundra TRD
    the other day I was coming to a stop and the left front brake sounded like the anti-lock system engaged (terrible noise). I continued to drive (very slowly) until I reached home. Each stop I had to make, the truck still felt like it was using the anti-lock brake system but only on the front left. When I got home I turned off the truck and restarted it and now it seems fine. Does anyone have any suggestions.
    thanks
  2. Aug 14, 2022 at 9:58 AM
    Hopefully it isn’t the ABS hydraulic actuator module/pump. Aftermarket is not too bad ~300.00. New from Toyota is 1100.00 or more.
    Have you serviced the brake fluid in the past?
  3. Aug 14, 2022 at 11:22 AM
    Retired Teacher
    It has been many years since I have flushed out brake fluid. Do you think this may help?
    Thanks
  4. Aug 14, 2022 at 5:58 PM
    Retired Teacher
    I have not checked to see if there are any codes but I will do this.
  5. Aug 14, 2022 at 6:28 PM
    Retired Teacher
    took the truck to auto zone and no codes.
