Brake Pad Shims
Discussion in '2.5 Gen Tundras (2014-2021)' started by TRDSteepSLOPE, Mar 30, 2022.
  1. Mar 30, 2022 at 12:58 PM
    TRDSteepSLOPE
    TRDSteepSLOPE [OP] New Member
    Kevin
    2019 Tundra CrewMax
    The Dealer is telling me that I should install brake pad shims with my OEM pads. I’m doing the install and this would be the first time I’ve heard of using a shim. Anyone have any input on this? Any Masters in here have a say?
  2. Mar 30, 2022 at 1:22 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    When I replaced the oem brakes a few years ago, my original brake pads had shims on them. I could have easily reused them if I had purchased oem brake pads. But since I went with an aftermarket setup of discs and pads, I didn't. I think the shims serve the purpose of reducing vibration and squeal. I just put some Stop Squeal on the back of the new pads. Never had an issue with it.
  3. Mar 30, 2022 at 1:38 PM
    TRDSteepSLOPE
    Kevin
    2019 Tundra CrewMax
    will my original OEM have them? Is there any concerns or problems to reuse if they are on?
  4. Mar 30, 2022 at 2:00 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    The original will have shims on them. Make sure you clean everything really good, and apply some brake lube to the shims and pins. When I replaced my pads I didn't clean or lube anything and had horrible brake squeal, so when I rebuilt my calipers I cleaned everything really good, and applied brake lube to everything. No more squealing. I used this stuff, seemed to really stand out from other products during my research
    https://www.amazon.com/CRC-05361-Si...t=&hvlocphy=9027658&hvtargid=pla-467954305081
  5. Mar 30, 2022 at 3:54 PM
    TRDSteepSLOPE
    Kevin
    2019 Tundra CrewMax
    Ordered thank you
    Sumo91[QUOTED] likes this.
  6. Aug 31, 2024 at 3:59 PM
    rag9836
    rag9836 New Member
    Robert
    Riverside, CA
    2021 Tundra TRD Pro Crew Max
    275/70/18 BFGs, TRD Cold Air Intake, BRShine LED light swap, FRAC front camera, ESP Under Seat Storage, Rocky Mounts bike holder, tinted front driver and passenger.
    Put some EDC yellow pads, they didn’t come with shims. Should I reuse the OEM shims on the yellow pads?
  7. Aug 31, 2024 at 4:16 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
    2nd this
  8. Aug 31, 2024 at 5:09 PM
    rag9836
    rag9836 New Member
    Robert
    Riverside, CA
    OEM shims on EBC pads? Yes/no?
  9. Aug 31, 2024 at 5:39 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    If they fit, why not?
    Newer EBC pads have come with shims that install on the pistons. I would not use both types.
  10. Aug 31, 2024 at 5:51 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    This I don't think a lot of people understand how important it is to clean clean everything and lube lube lube
  11. Sep 1, 2024 at 3:52 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Do not use OE shims on EBC pads. EBC pads come with the black shims, use that.
    Leo's first likes this.
