Brake lines failung
Discussion in 'Recovery & Gear' started by Gen1tom, May 15, 2023.
  1. May 15, 2023 at 9:57 AM
    Gen1tom
    Gen1tom [OP] New Member
    Wisconsin
    2013 Tundra 5.7 4WD crew cab
    Twice now I've lost brake pressure due to broken failing brake lines. The truck is currently in the shop for repair of the rear brake line splitter above the rear differential. The first time the brakes failed, it was the driver side upper line that comes down from the master cylinder. (Metal line). I'm just not sure if I trust this vehicle anymore when it comes to towing my boat or trailer. I'm also wondering if the lines are failing due to my mechanic putting the truck up on his lift. Could the stress on the frame be causing enough flex to cause the brake lines to start leaking? The truck was originally in the shop for a wheel bearing + front struts+ upper ball joint replacement.
  2. May 15, 2023 at 10:07 AM
    AZBoatHauler
    So.Arizona
    How often has the brake fluid been changed? Where are you located? Looking at the failure point should give some info if it was caused by corrosion or stress.
  3. May 15, 2023 at 10:10 AM
    Gen1tom
    Wisconsin
    Wisconsin resident. I bought the truck at 123,000 mi. Currently at 163,000. Just wondering if anyone has an estimate on a complete brake line replacement cost.
