brake lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by 99645 Tundra, May 29, 2019.
  1. May 29, 2019 at 11:15 PM
    99645 Tundra
    99645 Tundra [OP] New Member
    slic
    Palmer, Ak
    2016 tundra SR5
    none
    can't find break lights fuse, or fuse/relay
  2. May 29, 2019 at 11:31 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    It’s labeled “Stop” if my memory is correct, I think it’s in the fuse box under the hood, but might be under the left end of the dash.
  3. May 29, 2019 at 11:49 PM
    99645 Tundra
    slic
    Palmer, Ak
    2016 tundra SR5
    none
    ok will look into it
  4. May 29, 2019 at 11:50 PM
    99645 Tundra
    slic
    Palmer, Ak
    2016 tundra SR5
    none
    10:50 pm alaska time
  5. May 30, 2019 at 3:21 AM
    :threadjacked:
    Welcome from NY.
  6. May 30, 2019 at 4:41 AM
    Professional Hand Model
    Hand Protectors
    Time for a ‘break’.
    Newm and Sas like this.
  7. May 30, 2019 at 4:44 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Let's just put the BRAKES on all those BREAKS!:devil:
  8. May 30, 2019 at 5:17 AM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    My tundra doesn’t have a break light. Is that for when you’re not driving?
    Sas likes this.
  9. May 30, 2019 at 6:08 AM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    Sometimes when I'm driving for long periods of time I need to take a break so I'll brake and pull over to take a break
    Sas, Trooper2 and BestGen like this.
  10. May 30, 2019 at 7:46 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    In all my years I've never broken one. :thumbsup:
    15whtrd and Sas like this.
  11. May 30, 2019 at 4:03 PM
    madmatt
    madmatt New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    It’s that coffee cup ☕️ light on the dash! What’s wrong with you guys?
    Migraine and panicman like this.
  12. May 31, 2019 at 10:25 AM
    99645 Tundra
    slic
    Palmer, Ak
    2016 tundra SR5
    none
    fuse compartment underneath the steering column doesn't have fuse layout ID. I'm dead in the water folks need some help
  13. May 31, 2019 at 10:30 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    NewImprovedRon likes this.
  14. May 31, 2019 at 5:37 PM
    madmatt
    madmatt New Member
    Ocala Florida
    Did you find the fuse yet? It looks like it’s in the under hood box labeled “stop”
  15. May 31, 2019 at 8:03 PM
    99645 Tundra
    slic
    Palmer, Ak
    2016 tundra SR5
    none
    found fuse but still have the problem no break lights, changed both bulbs to fresh 1357s, and third break light bulb. checked break lever switch too still no luck finding out the problem
  16. May 31, 2019 at 8:20 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Stop installing break lights and install fixed ones.
    Tundyfundy, Newm and bdpeelgren like this.
  17. May 31, 2019 at 8:21 PM
    madmatt
    madmatt New Member
    Ocala Florida
    Did you do anything to it (change anything, add anything etc) when it went out
  18. May 31, 2019 at 8:26 PM
    99645 Tundra
    slic
    Palmer, Ak
    2016 tundra SR5
    none
    yes tried to install LEDs that i got from Amazon, that's when the trouble started, have no voltage at terminal sockets, when breaks applied
  19. May 31, 2019 at 8:27 PM
    madmatt
    madmatt New Member
    Ocala Florida
    Which ones did you install before the problem started?
  20. May 31, 2019 at 9:01 PM
    Remember to check the backup LP fuse under the dash.
  21. May 31, 2019 at 9:39 PM
    99645 Tundra
    slic
    Palmer, Ak
    2016 tundra SR5
    none
    the 3157 LEDs, Amazon indicated they fit my model and make, sorry i tasted them out in frustration. i noticed the LEDs don't have the "1357" markings on them. Iv even disconnected my battery for a hard reset
  22. May 31, 2019 at 9:59 PM
    99645 Tundra
    slic
    Palmer, Ak
    2016 tundra SR5
    none
    hey I found my fuse cover legend in door pocket
  23. May 31, 2019 at 10:21 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    It’s for when your Tundra Breaks, then the light comes on telling you it’s broken, so basically you’ll never see it.
    Sas likes this.
  24. May 31, 2019 at 10:28 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    This thread break'end...
    Sas and Tundyfundy like this.
  25. Jun 1, 2019 at 2:37 AM
    madmatt
    madmatt New Member
    Ocala Florida
    Ok, led lights are polar. They have to be put in the right direction to work unlike normal bulbs. That could be why they didn’t work. Secondly if you somehow shorted out the light itself (touched a piece of metal between both ends) then it blew a fuse. That would explain why none of the lights work now. You said you found the fuse legend or map, did you locate the blown fuse?
    War Machine and Tundyfundy like this.
  26. Jun 1, 2019 at 2:38 AM
    CMB
    CMB New Member
    Cecil County MD.
    Sas and Tundyfundy[QUOTED] like this.
  27. Jun 1, 2019 at 6:06 AM
    Sas
    OKC, OK
    One more try...
    Tundyfundy, Tundra Fan and bdpeelgren like this.
  28. Jun 1, 2019 at 6:07 AM
    bdpeelgren
    Round Rock, TX
    Speaking of the tundra breaks.... just received the email.
    Lambs tire and auto will check your breaks and your brakes.
    Tundyfundy and Sas like this.
  29. Jun 1, 2019 at 6:12 AM
    Sas
    OKC, OK
    :laugh: I have to wonder if they're covering their bases because they weren't sure which one was correct, of if it's a play on words to fix what's broken.
    Tundyfundy likes this.
  30. Jun 1, 2019 at 7:15 AM
    CMB
    CMB New Member
    Cecil County MD.
    What's it matter? "Correct" has been transformed or has evolved into "whatever we assume." I might have an unfair advantage over most people though, not to brag but I went all the way to the 10th Grade in schoolo_O:notsure:
