Brake light issue
Discussion in '2nd Gen Tundras (2007-2013)' started by Joseph C, Oct 22, 2020.
  1. Oct 22, 2020 at 8:52 PM
    Joseph C
    Joseph C [OP] New Member
    My taillights work, but when I press the brakes the driver side tail light goes out. Passenger side works fine. I’ve changed the bulb several times. I’m assuming the fuse and brake light switch are for both brake lights so haven’t checked those. I appreciate any thoughts or suggestions.
    YardBird likes this.
  2. Oct 22, 2020 at 9:05 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    I hope someone can help you with this issue.
  3. Oct 23, 2020 at 5:45 AM
    Joseph C
  4. Oct 23, 2020 at 6:12 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Have you traced the harness back?? Possibly a damaged wire, or corroded ground point which may interrupt the signal. I would suggest start there, if the passenger side works, odds are that fuses and relays are functional which may point to either the connector being damaged or a ground point down the harness somewhere.
  5. Oct 23, 2020 at 11:36 AM
    Joseph C
    @blackdemon_tt
    Thanks for the help. How difficult is that? Never done it. Specials tools I need or anything?
  6. Oct 23, 2020 at 11:43 AM
    blackdemon_tt
    Special tools? Depending on how young you are. You may need a creeper or some boxes on the ground.. additionally some eye protection and a wire brush. you will probably have to follow the bundle all the way down toward the cab and look for an exposed wires or even mounting point that may seem corroded...
  7. Oct 23, 2020 at 11:48 AM
    Joseph C
    Gotcha. Wasn’t sure if this was like multimeter territory or something.
  8. Oct 23, 2020 at 11:50 AM
    blackdemon_tt
    that's after you searched and don't find anything, you can always start with that as well.. but it will most likely lead you down the path that you need to look through the wiring, unless someone has a better idea, then take that as a better suggestion..
  9. Oct 23, 2020 at 1:20 PM
    Joseph C
    Appears to be the socket. Hard to find a replacement online.
  10. Oct 23, 2020 at 1:29 PM
    blackdemon_tt
    Is the socket damaged?? junkyard?? I'm sure its similar to other Toyota models, snap a pic and compare it to similar ones at the yards...
  11. Oct 23, 2020 at 3:48 PM
    Ericsopa
    Ericsopa Old man and the sea
