Brake light connection issue
Discussion in '1st Gen Tundras (2000-2006)' started by Otakutoaster, Dec 21, 2024.
  1. Dec 21, 2024 at 8:21 PM
    Otakutoaster
    Otakutoaster [OP] New Member
    WI
    2002 Tundra AC limited Black V8 4wd
    Radio, subwoofer & amplifier, Roll-N-Lock, Cabin air filter,
    How do I fix my passenger side brake light bulb. It keeps vibrating itself loose. I plugged it back in last week and it vibrated loose again a few hours ago.
  2. Dec 22, 2024 at 2:40 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I cut off a bit from the tip of a zip tie and jammed it in there...
    Otakutoaster[OP] likes this.
  3. Dec 22, 2024 at 2:46 PM
    shifty` I'm having daydreams about night things
    Get a pick inside and pop the pins so they put more tension on the bulb.
    If no joy, get a new connector; re-pin the old wires into the new one.
