Brake job question
Discussion in '2.5 Gen Tundras (2014-2021)' started by therealjonwick, Oct 18, 2024.
  1. Oct 18, 2024 at 3:41 PM
    therealjonwick
    therealjonwick [OP] New Member
    JR
    2019 OR
    Changing my front rotors and pads. As I’m pushing the pistons in I notice my main reservoir is about to overflow. Can I just suck some fluid out and replace more later? Any help would be great! What can I suck it out with?
  2. Oct 18, 2024 at 3:47 PM
    If you have never added any fluid to it just push the pistons in slowly. It shouldn't overflow. Once one side is done, pump the pedal to seat the pads and the fluid level will drop a little. If it really is full to the point of overflowing, you can twist some paper towels and stick one in to soak up some fluid and then top it off after you are done.
    OldGuy03 likes this.
  3. Oct 18, 2024 at 4:03 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Yes, you can.
    I use an old turkey baster. I also have a cheap transfer pump from Harbor Freight.
    pvn.beluga likes this.
  4. Oct 18, 2024 at 4:27 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    This is what I would do too.
  5. Oct 18, 2024 at 10:14 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Never really thought of this, I've changed my brake fluid but not brakes. Guess I'll keep an eye on the reservoir when it comes time.
  6. Oct 18, 2024 at 10:29 PM
    AZBoatHauler
    So.Arizona
    If changing calipers, why would you compress the pistons?
  7. Oct 19, 2024 at 1:59 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Although OP may have meant pads…
  8. Oct 19, 2024 at 6:54 AM
    therealjonwick
    JR
    2019 OR
    meant pads. Edited it. My bad.
  9. Oct 19, 2024 at 6:54 AM
    therealjonwick
    JR
    2019 OR
    Paper towel trick worked great. One side done last night. Driver side today.
    Tundra234 likes this.
  10. Oct 19, 2024 at 6:55 AM
    Open the bleeder screw on the caliper and push that nasty caliper fluid out, not back into the brake system
  11. Oct 19, 2024 at 7:43 AM
    Joe333x
    Joe333x Member
    Boston
    That's a solid idea! I'd hook up a mityvac and give it some vacuum just to make sure no air gets back in before you close it.
    AZBoatHauler likes this.
