Brake job in DFW area?
Discussion in 'Texas' started by gkelm, Jul 31, 2022.
  1. Jul 31, 2022 at 12:54 PM
    gkelm
    gkelm [OP] New Member
    DFW
    Our 2015 DC is getting to that point…haven’t done it myself and not sure I want to.
    Any suggestions? I’m in Keller, but don’t mind a little distance for good work.
  2. Jul 31, 2022 at 12:55 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    IMO, brake jobs on Tundras, and Sequoias, are some of the easiest to do. Provided you don't procrastinate to the point you need to turn or replace the rotors.
    equin and Bob like this.
  3. Jul 31, 2022 at 1:09 PM
    gkelm
    DFW
    Thanks, maybe should give it a shot. If only it wasn’t 100 degrees. :(
  4. Jul 31, 2022 at 1:15 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Tell me about it. I got tired of waiting for cooler temps and just keep a shop fan blowing on me everywhere I'm working
    RobertD likes this.
  5. Jul 31, 2022 at 1:48 PM
    RobertD
    Robert
    DFW, Texas
    Yeah... the first couple weeks we were in the 100s to put off a lot. But the heat isn't getting better so I've just accepted and tried to cope. Portable gazebo, fans, Gatorade, the cooling neck towels. All help but man I'm ready for like 80s lol
    gkelm[OP] likes this.
  6. Jul 31, 2022 at 2:04 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah man I am too. I don't mind getting hit with the heat in August, but we've had it pretty much since I went on summer break. My area has had over 25 straight days of above average heat.
    RobertD[QUOTED] likes this.
  7. Aug 3, 2022 at 11:29 AM
    gkelm
    DFW
    Any shop suggestions? Just don’t want to mess with it myself.
  8. Aug 3, 2022 at 11:53 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    It is a little pricy but I had the dealership do mine.
    I did my own brakes on my 2005, but that was when my knees were in better shape.
    @texasrho83 is correct, if it is a simple pad swap, it is fairly easy.
    But can see not wanting to do it yourself.
    Whatever you do, DO NOT GO TO NTB EVER, FOR ANYTHING..
  9. Aug 3, 2022 at 12:35 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Truth
  10. Aug 5, 2022 at 9:37 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Ratchet brothers (vendor for NTX tundra crew) if you're in Keller. They're off golden triangle/harmon. PCH Automotive is a family friends shop and ask for Jesse. I've known and used them for over a decade and they're in the same complex as Ratchet Brothers.
    texasrho83 and gkelm[OP] like this.
  11. Aug 5, 2022 at 10:27 AM
    gkelm
    DFW
    Awesome, thank you.
  12. Oct 28, 2022 at 1:04 PM
    gkelm
    DFW
    Ended up doing it myself with a hand from a buddy (former Tundra owner). Other than compressing the calipers and a set of black hands, wasn’t too bad!
    Was going to have the dealership do it for a $239 deal, but when they handed me a sheet with $6K recommended work, I got a bit torqued and walked out.
    The rotors ended up not looking all that bad, and the pads had some meat on them… but went ahead and replaced it all. Oem rotors and Akebono pads…about $200 total.
    Still need to sort out the other issue…supposedly the right rear bearing is worn and causing problems with the ABS and traction control.
    khooiii and AZBoatHauler like this.
  13. Oct 28, 2022 at 1:10 PM
    AZBoatHauler
    So.Arizona
    Nice work. I just did the rear brakes yesterday after doing the fronts last year. Still on factory rotors without a problem.
    I’m mentally prepping myself for bearing issues given I use my truck like a truck - has yours seen some heavy loads? Doesn’t look too bad to change out hubs…
  14. Oct 28, 2022 at 1:18 PM
    gkelm
    DFW
    Thanks. We’ve only haul the lightweight dirt bike trailer, but bought it with a little over 100k, so who knows.
