Brake issue
Discussion in '2nd Gen Tundras (2007-2013)' started by tundralover, Nov 8, 2015.
  1. Nov 8, 2015 at 6:26 AM
    tundralover
    tundralover [OP] New Member
    2007 SR5
    Have brake fluid leaking from rest driver side brake. Fluid visible on tire , wheel well and puddle on ground. Also brake is grinding on roter like it's locked or something. Any ideas?
  2. Nov 8, 2015 at 8:02 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You'll have to clean up the area and determine exactly where the fluid is coming from. Hose, fitting, or caliper. I would not suggest driving it though, it sounds like it's leaking quite a bit and could be extremely hazardous.
  3. Nov 8, 2015 at 1:08 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Is it Possible you wore the pads down so far the caliper over extended and started leaking from the piston?
    flynbyu2 likes this.
  4. Nov 8, 2015 at 1:59 PM
    flynbyu2
    flynbyu2 I'm your huckleberry...
    NorCal
    2015 SR5 CrewMax 2WD
    Flowmaster Super 50 / Dual In - Dual Out Exhaust BakFlipG2 Tonneau Cover TRD Rear Sway Bar
    Do any off-roading lately?
    I'd take the wheel off and have a helper push the pedal.
    If there's that much fluid, you should be able to see it weeping.
  5. Nov 9, 2015 at 2:34 AM
    George14
    George14 New Member
    West Virginia
    2014 Tundra SR5 Dc TRD Off Road 5.7L with tow package
    None
    X 2 what lotsoftoys said
  6. Nov 10, 2015 at 2:07 PM
    flynbyu2
    NorCal
    Well????? We need to know what it was....
