Brake issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shawnml9, Sep 20, 2023.
  1. Sep 20, 2023 at 10:18 PM
    Shawnml9
    Shawnml9 [OP] New Member
    2019 tundra
    Replaced front pads (spongy pedal) now, did not remove cap while closing calipers did lose fluid, fluid in resevoir is just below cap at moment..I noticed rubber cap is vented or I blew it up, but appears like it was designed to vent...Thoughts?
  2. Sep 21, 2023 at 9:08 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Pads will feel a little spongy until they break in.
    cap has a rubber layer under the plastic cap. The rubber part is to seal the reservoir, but the cap is vented to allow the rubber part to move (it will get sucked into the reservoir when fluid goes down, back up with increased volume etc).
    equin and Shawnml9[OP] like this.
  3. Sep 21, 2023 at 2:01 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    do a brake fluid flush; you may have introduced some air into the system
    EmergencyMaximum likes this.
  4. Sep 21, 2023 at 2:08 PM
    EmergencyMaximum
    EmergencyMaximum New Member
    By 'spongy pedal', do you mean braking is bad, gang? I usually do some brake tests after bleeding and she should brake very well! Mine can easily abs with new tires and dry pavement.
  5. Sep 21, 2023 at 4:46 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Have you ever done the brake fluid? If you havent I would. Should change it about every 2 years or so.
  6. Sep 21, 2023 at 5:04 PM
    Shawnml9
    2019 tundra
    Have not yet. May attempt to replace rears tonight if back and legs allow it. Lol
  7. Sep 21, 2023 at 5:37 PM
    When compressing the calipers, crack the bleeder open to send the old contaminated brake fluid out of the system, rather than compressing the dirty fluid back through your ABS system. You said you lost fluid? Where did it go?
  8. Sep 21, 2023 at 5:52 PM
    Shawnml9
    2019 tundra
    Didn't lose, pads were so low when I had oil changed they filled it (found that out today) so when I compressed it came out cap...all making sense now I was befuddled last night
    KNABORES likes this.
  9. Sep 21, 2023 at 6:23 PM
    EmergencyMaximum
    Did you spray it off with water? Please do, so that your body won't rust to hek.
    If you never changed brake fluid and squeezed all that old one back into the system, that cannot be very optimal for health of the brake system.
  10. Sep 21, 2023 at 6:26 PM
    Shawnml9
    2019 tundra
    Did not spray off but will, this is the first brake job on this truck.
    Thanks
  11. Sep 21, 2023 at 6:29 PM
    EmergencyMaximum
    Yes, please do so when you can. Brake fluid is hydroscopic. Water will dilute and neutralize it, hence preventing body damage.
