Brake info for the future.
Discussion in 'New Member Introductions' started by BRD13420, Mar 27, 2024.
  1. Mar 27, 2024 at 8:40 AM
    BRD13420
    BRD13420 [OP] New Member
    I read something posted on this site about brake shimmy, and wanted to give some free advice to those less mechanically inclined. 90% of the time, shaking when applying the brakes is going to be caused by the rotors, either being worn out, or just worn and can be saved by machining/turning them. I know I'm sounding like captain obvious to the mechanically inclined people here, but hopefully it will help other's that aren't. I just got a 2000 Tundra and I'm looking for a front brake upgrade option. Any suggestions?
  2. Mar 27, 2024 at 8:44 AM
    If the brakes start to shimmy, they are likely warped. Trying to turn warped rotors is futile. Most rotors these days are thin to start. After some use, they become to thin to turn, if they are indeed just grooved, and not warped. If your 2000 still has the original brakes with the WE calipers, an upgrade to the WL calipers will help. These became standard in 2003 due to brake system performance complaints. PowerStop makes a nice WL upgrade kit.
    Weagle and FrenchToasty like this.
  3. Mar 27, 2024 at 8:49 AM
    BriannaSTILLEN
    BriannaSTILLEN New Member
    Brianna
    Hey OP, I have some brake options for you. We have drilled & slotted (or just drilled, or just slotted) brake kits available for the front of the 2000 Tundra. Just need to know if you have the 1st caliper type (4.7" pad length, caliper casting S13WE) or 2nd type (5.3" pad length, caliper casting #3WL). And SUPER good prices. Photo for reference. [​IMG]
    FrenchToasty likes this.
  4. Mar 27, 2024 at 3:07 PM
    Welcome from NY.
  5. Mar 27, 2024 at 7:46 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
