Brake fluid service while pads are fine?
Discussion in '2.5 Gen Tundras (2014-2021)' started by blaserdude, Sep 20, 2022.
  1. Sep 20, 2022 at 9:11 AM
    blaserdude
    blaserdude [OP] New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    My dealership is recommending brake fluid service (50K miles). I have heard of this when new pads are installed but mine are far from gone. Thoughts??
    BC
  2. Sep 20, 2022 at 11:31 AM
    Taco-Spike
    Two Trucks
    It's just a fluid flush right?
  3. Sep 20, 2022 at 11:43 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Brake fluid is always over looked. Brake fluid absorbs water, therefore it need to be changed out. How much do they want for this service?
    HulkSmurf14, omgboost and Taco-Spike like this.
  4. Sep 20, 2022 at 11:55 AM
    blaserdude
    Eugene
    none
    I did not ask. I was in a hurry.
    Will inquire.
  5. Sep 20, 2022 at 11:56 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    some dealer don't even do a full flush, they just change brake fluid inside the reservoir
    WILLINH likes this.
  6. Sep 20, 2022 at 12:06 PM
    timsp8
    NY
    Get one of those brake bleeder containers with a one way valve and you can do all 4 yourself in 30 min with most of that time spent crawling under the truck to move the container. Will probably take 3 or 4 quarts or so depending on how thorough you want to flush it.
    HulkSmurf14 likes this.
  7. Sep 20, 2022 at 12:13 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Brake fluid is typically every 2-3 years.
  8. Sep 20, 2022 at 2:18 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    They are just after your money. Then only time I have changed it is when replacing a master cylinder or bleeding brakes after pad replacement.
    Malinois38 and Leo's first like this.
  9. Sep 20, 2022 at 4:56 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Should replace brake fluid every two years, doesn't matter the milage. Usually the reason you get a stuck caliper is due to the brake fluid never being changed. Using a mighty vac, its pretty easy, theres also an app on techstream you can use to make sure they are bled properly afterwards.
    JLS in WA likes this.
  10. Sep 20, 2022 at 5:15 PM
    blaserdude
    Eugene
    none
    Thanks. I have never in over 50 years of driving had this done unless the MC was replaced. It can't hurt other than my bank account, however. Had one stuck caliper on a Mercury that was seldom driven.
    WILLINH likes this.
  11. Sep 20, 2022 at 5:18 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I agree don't do it unless replacing master cylinder. You bleed yourself and pump the master cylinder dry now you have a real headache. Devil in the details.
  12. Sep 21, 2022 at 4:25 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
  13. Sep 21, 2022 at 2:58 PM
    eagleguy
    eagleguy New Member
    What does the owners manual say? I was told the new synthetic fluid used does not need to be changed as often but guess it can't hurt.
  14. Sep 21, 2022 at 3:05 PM
    agrestic1
    2016 CrewMax
    My 2016 Owners manual says check and adjust...
  15. Sep 21, 2022 at 3:07 PM
    Joe333x
    Joe333x Member
    Boston
    Recommended interval regardless of mileage is two years. Do most people do that? Of course not. Will it effect your braking performance if you don't change it? Most likely not. What it will do is collect moisture over time that will eventually require you to replace things like calipers. Brake fluid is cheap and rather simple to do with a tool like a MityVac. I neglected to change rear brake fluid on a motorcycle for probably 15 years and the brakes still worked but the fluid collected tons of crap and was dark brown. Suzuki actually had a recall once because neglecting to change the brake fluid would eventually cause corrosion in the master cylinder and produce the safety hazard.
  16. Sep 21, 2022 at 3:09 PM
    AZBoatHauler
    So.Arizona
    I’m still on my factory fill but it is my next maintenance item. Probably get to it next month.
  17. Sep 21, 2022 at 3:12 PM
    timsp8
    NY
  18. Sep 21, 2022 at 4:19 PM
    agrestic1
    2016 CrewMax
    Put it on my list. My only concern is frozen bleeders .....
  19. Sep 21, 2022 at 4:20 PM
    cougarhound
    cougarhound New Member
    Better than replacing calipers and rusted brake lines. Easy to do
    Retired...finally likes this.
  20. Sep 21, 2022 at 6:34 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Because DOT 3 and 4 attract water and the brake circuit is not completely sealed, you’ll eventually rust out the steel brake lines.
    Flushing is a good idea, and I’d think that every couple of years is fine.
    I have a vehicle from 1960, and I 3 years ago changed out the soft lines and MC. At the same time, I totally bled the system and then flushed and filled with DOT 5. DOT 5 does not attract water.
    I have had no issues whatsoever.
    Has anyone done DOT 5 in a tundra?
  21. Sep 21, 2022 at 6:44 PM
    Joe333x
    Joe333x Member
    Boston
    DOT 5 is not compatible with DOT 3 or 4 systems. DOT 5.1 can be used with 3 or 4, but DOT 4 and 5.1 attract more water than DOT 3 and you don't need the higher boiling point of 4 or 5.1 in a Tundra.
  22. Sep 21, 2022 at 10:35 PM
    panicman
    Eric
    Hold on- help me understand…
    I know that you can’t add DOT 5 to a DOT 3 or 4 system while the system still has residual 3 or 4 fluid present.
    but if you replace the MC, soft lines, etc…, and then fully flush the system with 5, then how is there an incompatibility?
  23. Sep 21, 2022 at 10:36 PM
    Joe333x
    Joe333x Member
    Boston
    DOT 5 can not be used in ABS systems.
    panicman[QUOTED] likes this.
  24. Sep 22, 2022 at 12:21 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  25. Sep 22, 2022 at 12:41 AM
    Joe333x
    Joe333x Member
    Boston
    This is definitely true, brake fluid doesnt really circulate much so even if the reservoir looks clear the fluid in the lines could be pretty dirty. Its not much more work to just flush the whole system while you're at it though if you're doing it yourself, only takes about 2 quarts.
    snivilous and WILLINH like this.
  26. Sep 22, 2022 at 12:31 PM
    cougarhound
    DOT 5 is popular in classic cars because it doesn't eat paint..but I believe that is it's only advantage. Supposedly it sucks and racing guys don't use it for the same reason it is not used in ABS systems. It has a tendency to create bubbles. I was considering it for my vintage car project so I did some research.
    Joe333x likes this.
  27. Sep 22, 2022 at 12:40 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Track racing have to abs delete.
  28. Sep 22, 2022 at 12:44 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    It takes longer to drive literally anywhere than to flush the fluid yourself with someone helping. You just need a hose and a container and bottle or two of fluid. Crack the bleeder, have someone pump the brakes a handful of times, refill resi, rotate around. Takes maybe 15 minutes.
  29. Sep 22, 2022 at 12:53 PM
    cougarhound
    How do you guys dispose of brake fluid? Part of the reason why I pay people is because I never know what to do with the chemicals....and no I'm not going to dump it in my backyard. I have well water.
  30. Sep 22, 2022 at 1:33 PM
    Joe333x
    Joe333x Member
    Boston
    You put the old fluid in the container it came it and return it to where you bought it. I just returned 5 jugs of oil at Walmart and bought another 5. You just go up to the service desk and theres usually a blue metal box you put them in. Almost anywhere that sells oil will take it back. Obviously dont dump it in your backyard, even if you didnt have well water. Considering its free to dispose of the right way.
    cougarhound[QUOTED] likes this.
