Brake Fluid Reservoir Level
Discussion in 'General Tundra Discussion' started by Professional Hand Model, Sep 18, 2018.
  1. Sep 18, 2018 at 4:41 AM
    Professional Hand Model [OP] A.K.A ‘Golden Hands’
    Hand Protectors
    Top it off (as in max it to the rim before overflowing)? Or, just take it to the ‘max/min lines’?
    Reason for asking is a theory about keeping any air (thus moisture) out of the reservoir by maxing to the rim.
  2. Sep 18, 2018 at 4:43 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Just to the max line. The small amount of moisture in that space isn't enough to be concerned with.
  3. Sep 18, 2018 at 4:50 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  4. Sep 18, 2018 at 7:00 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Just to the max line. Then flush it every so often to keep it fresh.
  5. Sep 18, 2018 at 4:21 PM
    Hand Protectors
    Sas[QUOTED] likes this.
  6. Sep 18, 2018 at 7:38 PM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    If you do top it off, remember to suck some out before changing your brakes when that time comes. As brakes wear, the fluid level drops to compensate for pad wear .When the Pistons are retracted back, as is necessary to accommodate new pads, the overage will spill out.
