Brake enough to tow
Discussion in '1st Gen Tundras (2000-2006)' started by Mschuff, Jan 24, 2022.
  1. Jan 24, 2022 at 1:14 PM
    Mschuff
    Mschuff [OP] New Member
    2006 Double Cab
    I have turned my rotors and replaced the pads up front. I replaced the shoes and adjusted in the rear. I am still not getting the stopping power I would be comfortable with while towing. Break fluid level is consistent, no signs of leaks. I don’t run big tires. I bled the brakes. Any thoughts?
  2. Jan 24, 2022 at 1:19 PM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    Does your trailer have brakes?
    If so, are you sure they are working?
    SPP
  3. Jan 24, 2022 at 1:36 PM
    Mschuff
    2006 Double Cab
    I won’t even drop a trailer on this truck until I get these truck brakes operating better. It’s not stopping strong enough to feel comfortable taking my kids in it.
  4. Jan 24, 2022 at 1:37 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    To clarify, are you not getting the stopping power you expect while towing (trailer attached) or not enough that you would be comfortable to try towing?
  5. Jan 24, 2022 at 1:39 PM
    mountainpete
    @Mschuff - you replied as I replied. :)
    I had a similar problem on a Tacoma. I upgraded the brakes to Tundra brakes and I couldn't lock the wheels in an emergency stop. It was two things: rear brakes were not adjusted properly and there was air in the brake lines.
  6. Jan 24, 2022 at 1:40 PM
    Mschuff
    2006 Double Cab
    Not enough to be comfortable to tow.
  7. Jan 24, 2022 at 1:43 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Keep adjusting your rears
  8. Jan 24, 2022 at 1:55 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Did you bleed the load sensing proportioning valve?
  9. Jan 24, 2022 at 1:58 PM
    :thumbsup:
  10. Jan 24, 2022 at 2:33 PM
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    Flush the old brake fluid. Moisture in the braking system can cause lose in braking.
    You might have to replace the disc's up front, if you turned the rotors more then once.
    Also some members complain about using aftermarket brake parts.
    Look under Brake Replacement Options
  11. Jan 24, 2022 at 6:36 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Flush all the fluid. Adjust the rears until they rub, then back off a click or two. Maybe adjust the load sensing valve.
    ive got the powerstop z23 pads and cryo rotors, but in sept i had to two-foot emergency brake because of a deer, and felt the abs working, and last week i towed almost 6000lbs and felt comfortable with my brakes.
    FrenchToasty likes this.
  12. Jan 24, 2022 at 7:16 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    DarkMint likes this.
  13. Jan 25, 2022 at 6:40 AM
    Mschuff
    2006 Double Cab
    It seems that bleeding the load sensing proportioning valve is my next step. And then adjusting it as well. Thanks y’all. I’ll report back
    bmf4069 and des2mtn like this.
  14. Jan 25, 2022 at 6:42 AM
    des2mtn
    SW
    Tonto cover
    Best of luck! Here's the order you'll need to bleed it in per the factory service manual:
    Passenger rear
    LSPV
    Driver rear
    Passenger front
    Driver front
