Brake drum issues
Discussion in '2nd Gen Tundras (2007-2013)' started by M2tundra, Nov 5, 2022.
  1. Nov 5, 2022 at 5:27 AM
    M2tundra
    M2tundra [OP] New Member
    2007 Tundra Crewmax
    I’m a newb here. I recently replace front and back brakes and rotors. When I was replacing the left rear brake and rotar the pad was worn to the metal, it was the only one out of 4 worn. I replaced it and that rotor is now completely worn out. I had replaced the calipers as well but don’t have a clue what happened. Any suggestions?
  2. Nov 6, 2022 at 10:21 AM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    So your new rotor and/or pad(s) are wore out on the same side?
    Typically uneven pad wear is a caliper piston problem(seized or sticking). Not greasing the caliper slide pin can do it too.
