Brake Dilemma
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by JackWagon, Aug 16, 2017.
  1. Aug 16, 2017 at 12:03 PM
    JackWagon
    JackWagon [OP] Dr. Wookiee
    16 Tundra DC TRD Pro MGM
    Hey Everyone. I'm in the market for new brakes (close to 50K on the Pro) as I'm currently getting a vibe when slowing down. I think I've got it narrowed down to the 2 following "kits". I'm planning on doing front and rear for peice of mind. My Pro is daily driven w/ maybe 10% offroad use. Do slotted/drilled rotors really make that much of a difference over smooth? What about any kind of offroad use? What is the difference between the Green/Yellow and Ultimax? Please let me know your thoughts.
    EBC Brake Kit:
    EBC Premium Brake Rotors (smooth)
    EBC Ultimax brake pads
    ...This kit allows for substitution of slotted/drilled rotors and green/yellow brake pads...
    http://www.autoanything.com/brakes/ebc-brake-kits?VehicleId=8213772
    -vs-
    Power Stop Truck & Tow Brake Kit:
    Power Stop Drilled/Slotted Rotors
    Power Stop Z36 brake pads
    ...This would have to be peiced together to get fronts and rears (RockAuto has everything for about $333)...
    http://www.autoanything.com/brakes/61A5871A0A0.aspx
    http://www.autoanything.com/brakes/61A2854A0A0.aspx
    http://www.autoanything.com/brake-pads/power-stop-z36-truck-tow-brake-pads
  2. Aug 16, 2017 at 12:11 PM
    Ebc. All you need
  3. Aug 16, 2017 at 12:30 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I have a 67 camaro... I did a 4 wheel disc conversion and at the end of it - was mighty peeved with the return on investment.... stopping took way too much planning in my opinion.
    Someone told me to try EBC yellows before I dropped several grand on a baer system.... holy crap - best $100 I've ever spent. Braking is ridiculous you'd never guess that was all I changed. I don't know what the difference is between yellow/green and so on but their website is pretty good at directing you. For my needs, yellows fitted the bill and they're ridiculously good.
    040Tundra and NewImprovedRon like this.
  4. Aug 16, 2017 at 12:54 PM
    JackWagon
    If EBC is the way to go.... Which option?
    Premium Rotors w/ Ultimax f/r = $292
    Premium Rotors w/ Yellowstuff f/Ultimax r = $353
    Premium Rotors w/ yellowstuff f/r = $387
  5. Aug 16, 2017 at 12:56 PM
    tomsinamerica
    Tom
    Wilmington, NC
    do you need rotors - are they warped? If it were me, I'd just lathe them and put pads on.
  6. Aug 16, 2017 at 1:17 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I just decided to purchase a set of StopTech slotted rotors and pads.
    FlashCulprit likes this.
  7. Aug 16, 2017 at 1:18 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I put the z36 powerstop pads and slotted/drilled on my 2004 tundra access cab 4x4 and it was markedly better than OEM. I can't speak to EBC but I have always heard good things about them
    FlashCulprit and JackWagon[OP] like this.
  8. Aug 16, 2017 at 1:21 PM
    TheBeast The Beach
    subscribing
  9. Aug 16, 2017 at 1:40 PM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
  10. Aug 16, 2017 at 2:12 PM
    JackWagon
    I feel like my rotors are warped because of the shimmy/vibration I get in the brake pedal as well as the steering wheel. This as well as peice of mind are why I am going with front & rear rotors & pads. I'll be getting tires before winter also. Gotta start off fresh.
    040Tundra likes this.
  11. Aug 16, 2017 at 2:23 PM
    TheBeast The Beach
    could it be bad balancing on your tires or even alignment ?
  12. Aug 16, 2017 at 2:24 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    With my experience on my old much lighter Tacoma, the drilled and slotted rotors make a tiny difference in performance. But they last much longer than regular rotors. No experience yet with the much heavier Tundra.
  13. Aug 16, 2017 at 2:54 PM
    JackWagon
    Truck tracks straight, so alignment should be ok. I'm not ruling the tires out, but I don't have any vibrations while driving. Only braking. There is about 1 ware bare left on the factor michelines, so new tires are being researched. Either 305/65 Wildpeak AT3W or 285/70 EXO Grapplers.
    4x4_Angel likes this.
  14. Oct 8, 2017 at 7:01 AM
    lehminh
    lehminh New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
  15. Oct 29, 2017 at 6:35 AM
    JackWagon
    I haven’t done anything brake wise yet. Still figuring out what I want to go with. New tires are on.
    Are slotted and drilled worth it or are regulars just fine? The EBC standard rotors with a yellow stuff or something like that might be the route I go. We shall see.
  16. Oct 29, 2017 at 9:07 AM
    n2deep
    n2deep Pavement Princess
    Seems weird that so many have issues with the stock rotors. I towed a boat and off-road pretty hard all in the southwest desert without any issues. Changed to hawk pads at 50k and just replaced again at 100k still on the stock rotors since they are still within spec. I would have them turned, add new pads and see if that fixes it before dropping money on new rotors. I have done slotted and drilled on other vehicles and the only different I noticed was in my pocket book.
  17. Oct 29, 2017 at 9:15 AM
    lehminh
    lehminh New Member
    Took my Tindra in for 15k service and asked them to look into the braking vibration. They confirmed warped rotors, I haven't towed anything yet. They charged me $120 to even out the rotors, said it was wear and tear and not covered even though it's only 15k miles.
    Berkdawg likes this.
  18. Nov 5, 2017 at 7:39 AM
    Cisko213
    Cisko213 New Member
    So Cal
    2016 Tundra TRD Pro
    Retrofit Headlights, Baja Design Fogs
    Would think the brakes on the Tundra should last allot longer than what you guys are saying. At least 100K
    driverdog likes this.
  19. Nov 5, 2017 at 7:52 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I had to replace my pads w/ EBC ceramic at about 35k miles, rotors were fine.
  20. Nov 5, 2017 at 8:27 AM
    Cisko213
    Cisko213 New Member
    So Cal
    2016 Tundra TRD Pro
    AC Delco brakes last over 100,000 miles. But the problem with that is they outlast the trucks...
  21. Nov 5, 2017 at 8:30 AM
    TheBeast The Beach
    my rotors were wrapped at about 53K. I swapped to some slotted ones from Stop Tech. oem pads were still good but since I was working on brakes I installed ceramic ones. Brakes really well now and no more vibrations.
  22. Nov 5, 2017 at 8:53 AM
    Tundraboomer
    Tundraboomer New Member
    I ordered and installed the Power Stop Z36 front brake kit on my 2012 4X4 this past September after having some rotor warping issues after 80,000+ miles on the original brakes. I then promptly did a 4,500 mile road trip and they performed great. I now have about 6,000 miles on them and they are great so far but time will tell.
  23. Nov 5, 2017 at 9:00 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Out last what trucks? chevy? dodge? I'm sure you're not talking tundras.....
    TheBeast likes this.
  24. Nov 5, 2017 at 9:49 AM
    Tundraboomer
    Only if you drive like a granny and never tow anything. Brake life is definitely a YMMV thing.
  25. Nov 9, 2017 at 9:53 PM
    Cisko213
    Cisko213 New Member
    So Cal
    2016 Tundra TRD Pro
    Yeah AC Delco brakes outlasted their own trucks, Chevy, GMC
    4x4_Angel[QUOTED] likes this.
  26. Nov 9, 2017 at 9:54 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    Shit i would love brakes to last forever......one less maintenance bill to pay
  27. Nov 9, 2017 at 10:29 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    I went Powerstop as well... Seen a handful of guys I used to wheel with use them and people swear by them in the pre running scene when they can't afford brembos.
    200 and some odd bucks for carbon ceramic pads and drilled slotted rotors. about 15k on them and they still feel absolutely perfect.
    Stock vs OEM - Much beefier.
    I started a thread about this a while back. Feel free to check it:
    https://www.tundras.com/threads/which-brakes-are-you-running-poll.13610/page-2
  28. Nov 9, 2017 at 10:30 PM
    FlashCulprit
    Joe
    Salt Lake City, UT
    Shoulda painted those mama's! ;)
