Brake controller
Discussion in 'Towing & Hauling' started by Jsb111, Aug 22, 2017.
  1. Aug 22, 2017 at 3:22 AM
    Jsb111
    Jsb111 [OP] New Member
    Just got my new 2017 Tundra. I tested the brake controller out. I get lockup using the manual control but without using the manual control I need to put the Gain up to 10 to feel the brakes kick in. On my old vehicle I could feel the trailer pulling on the tow vehicle when stopping. I don't get the same feeling with the built in control. Is this normal?
    I've read there was a recent update to the controller. I'm in Canada...anyone know if the TSB applies here too?
    Lastly if I decide to put in a new controller is there a separate port or do I have to disconnect the built in one?
  2. Aug 22, 2017 at 4:39 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Good questions, I have a 14' without the factory controller so I don't know the answers to your questions, but I'm sure someone will chime in with some knowledge!
  3. Aug 22, 2017 at 5:15 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    i have a 16 my factory controller sucked. got a p3 with harness and a esp mount looks great works amazing. just plugs in to factory connector. un hook battery in truck so you dont get error message on dash
    757TUNDRA and ColoradoTJ like this.
  4. Aug 22, 2017 at 5:19 AM
    This^^^^^
  5. Aug 22, 2017 at 11:56 AM
    Jsb111
    So I was at the dealer today and apparently my controller already has all the updates. So I ordered a proportional controller on Amazon. Got the Tekonsha 90160 Primus IQ Electronic Brake Control. Hopefully it's easy enough to install. I'm assuming I just disconnect the factory one and use that cable?
    ColoradoTJ likes this.
  6. Aug 22, 2017 at 12:17 PM
    kurtwp
    kurtwp What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
    Don't forget to keep us posted on your install of the brake controller.
    Kurt
  7. Aug 22, 2017 at 1:06 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    When I installed my Prodigy 2 I needed an cable that plugs into the internal brake controller cable and adapts to the new controller.
  8. Aug 22, 2017 at 3:41 PM
    Tundraplatinum
    2016 Platinum CM
    Amazon has the cable you need but you gotta buy it separate. You really should go with Tekonsha p2 or p3 esp makes a mount so it looks clean af
  9. Aug 22, 2017 at 5:36 PM
    Jsb111
    I don't need anything fancy...just want something that works better than the factory controller. I ordered the cable too. Unfortunately Amazon in Canada doesn't carry it, but ordered it from a different site.
    NewImprovedRon likes this.
  10. Aug 26, 2017 at 4:33 PM
    Jsb111
    Installed it earlier this week and tested today. Works great. Much better than the factory controller. I can actually feel the trailer braking now.
  11. Aug 27, 2017 at 10:37 AM
    kurtwp
    kurtwp What
    Kurt
    Charlotte, NC
    You have pictures of your install.
    Kurt
