Brake controller issue with no answers.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rusty57, Feb 21, 2023.
  1. Feb 21, 2023 at 5:05 PM
    Rusty57
    Rusty57 [OP] New Member
    Hector
    2017 Crewmax
    I have a 2017 Crewmax. 2 wheel drive. The Brake controller warning lit up the dashboard like Christmas. Took it to the dealer. They diagnosed a faulty left rear wheel speed sensor (fault code C0215) Way to expensive to fix there, so I took it to a local mechanic. Replaced the sensor, still have the issue. Found 2 other codes that have nothing to do with the brake system. Recommend fix….new battery. Went to Autozone, they said the Yellow Top Optima I have is just fine. Called an auto electric place and they said $160 an hour to diagnose the issue. I’m at a loss here. Any ideas or suggestions? Thank you in advance.
  2. Feb 21, 2023 at 5:10 PM
    How is the wiring or the plug on the wheel sensor?
  3. Feb 21, 2023 at 5:16 PM
    Rusty57
    Hector
    2017 Crewmax
    Looked just fine, no corrosion or frays.
