Brake Controller Error
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1Tundra6, Jan 19, 2020.
  1. Jan 19, 2020 at 8:48 PM
    1Tundra6
    1Tundra6 [OP] New Member
    Hello all, I have a 2016 Tundra.
    When I started it up today in the driveway, it came up with a "Brake Controller Error, If towing, come to a safe stop with manual controls. contact dealer"
    The ABS and Traction control lights are also lit up.
    I connected my ODB2 scanner and it says there are no codes.
    Search showed me someone else with the same problem and it was an ABS sensor going out.
    Would that come up as a code?
    Any help would be appreciated .
    Thanks
  2. Jan 21, 2020 at 11:16 AM
    1Tundra6
    I took it to the dealership, rodent damage on the wiring harness in the engine bay
  3. Jan 21, 2020 at 11:24 AM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    Bummer. Dang rodents
  4. Jul 22, 2020 at 7:09 AM
    madgenius
    madgenius New Member
    Springtown, TX
    2016 Toyota Tundra TSS 4x4
    Carven exhaust, S&B Cold Air Intake, 6" RC Lift w/ 35's
    Mine lit up yesterday. It's at the dealership right now. Once I get it taken care of I'll let yall know what caused mine to go nuts. Seems to happen a lot based on all the posts I see.
  5. Aug 24, 2020 at 11:08 AM
    kevine0001
    kevine0001 New Member
    Kevin
    Following, I got the same message while driving on freeway. Turned off after half hour, and has not come back on. I have a 2017 with extended warranty on CPO. Taking it in this Wed. Hoping it's covered.
  6. Aug 24, 2020 at 11:18 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    following
  7. Sep 5, 2020 at 11:56 AM
    madgenius
    Springtown, TX
    ***UPDATE***
    Ok, Good news and bad news. After about 2 1/2 weeks and $3200 they have fixed the issues. The first time they changed out the Brake Actuator Assy, and the Trailer Brake Relay. I drove it about 2-3 days and al the lights came back on. I was furious. Took it back to them and they changed out the Right Rear Axle Bearing Assy and a bunch of small components that go with that. Been about 2 week now and I've have had no issues. Multiple posts on the Toyota forums had mentioned the rear bearings being the culprit. It was for me too, plus some other things. Hope this helps yall out and you don't have to go out of pocket as much as I did.
  8. Sep 5, 2020 at 1:52 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    Thanks for the update!
    I see you're from Springtown. I have family in Agnus. I spent a lot of time out there growing up. They used to own the carpet store & sub shop in Springtown years ago. My cousin is a coach @ the HS.
  9. Sep 7, 2020 at 8:33 AM
    madgenius
    Springtown, TX
    I'm really liking Springtown. I moved out here about 2 yrs ago now. There's a lot of building going on out here so this place is growing.
  10. Jan 2, 2021 at 8:16 AM
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    Thanks for all the info everyone, will be chasing this gremlin when I get home. 2016 w/43,000 miles
  11. Sep 22, 2022 at 9:20 PM
    nj636
    nj636 New Member
    NJ
    2017 Super White TRD
    +1 for axle bearing taking a shit causing the warning message to come on. 170k on my 2017
