Brake Assist & Smart Stop Technology
Discussion in 'Towing & Hauling' started by skifreak, Jan 31, 2023.
  1. Jan 31, 2023 at 7:01 AM
    skifreak
    skifreak [OP] New Member
    North Carolina
    2015 Tundra SR5
    Tekonsha brake controller
    According to my specs, I have the subject item but there are no gain or manual switches. Can someone enlighten me about this?
    Also, would adding a 3rd party brake assist controller be redundant?
    Vin - 5TFRY5F10FX182571
    i also saw videos where the cable could be somewhere under the steering column to connect to a brake controller.
    Thanks in advance,
    Mark
  2. Feb 1, 2023 at 7:39 AM
    skifreak
    North Carolina
    2015 Tundra SR5
    Hello?
  3. Feb 1, 2023 at 10:02 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    There are no controls for either Brake Assist or Smart Stop.
    Brake Assist can vary the pressure sent to each wheel/brake, depending on conditions. Smart Stop prevents unintended acceleration by disabling a throttle input when the brake pedal is applied above a certain speed. They are just built in and always there.
    For the trailer brake controller, I can't remember exactly but I think the integrated controller was added in '16. Since yours is a '15, I assume you don't have that, so you would not have a gain/control switch. You would need to install a 3rd party brake controller. I had to do that with my Tacoma. In the Tacoma, there was a wiring connector under the dash. I just had to buy a wire adapter specific to my truck to connect up the brake controller. Worked really well. I seem to recall reading on here that it was the same setup with the Tundra, that you do have a connector under the dash to plug in to. Others will know better than I as I just use my integrated brake controller that my truck came with.
  4. Feb 1, 2023 at 10:05 AM
    If a trailer has electric brakes, you don't use the integrated controller right?
  5. Feb 1, 2023 at 10:05 AM
    skifreak
    North Carolina
    2015 Tundra SR5
    Thanks for the explination. i have a brake controller from my old truck i am going to use, just have to find the wire.
  6. Feb 1, 2023 at 10:06 AM
    JDR76
    JDR76 New Member
    WA
    Even with electric trailer brakes, you still need a brake controller.
    skifreak[OP] likes this.
