Brackets for use with Toyota Bed Rails?
Discussion in 'General Tundra Discussion' started by tundracap, Jan 3, 2019.
  1. Jan 3, 2019 at 8:10 AM
    tundracap
    tundracap [OP] New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    Looking for some type of brackets to use in mounting boxes (small, ammo can sized) to the bed rails. I already have T-nuts to slide into the rails. Just need some type of brackets that would be used to support or mount storage boxes to.
    Looked at the Rago brackets, but just haven't found what I am looking for.
    Would like to get the boxes mounted up in the forward corners of the bed nearest the cab.
    Maybe some heavier L-shaped brackets.
    May have to fabricate what I really want, but looking for ideas on anything available already.
    TIA.
    Black Wolf and OR18TRD like this.
  2. Jan 3, 2019 at 5:48 PM
    Our wonderful mod @csuviper mounted ammo cans to bed rail.....
    csuviper and 4x4_Angel like this.
  3. Jan 3, 2019 at 5:48 PM
    tundracap
    NC
    Sas and OR18TRD[QUOTED] like this.
  4. Jan 3, 2019 at 5:49 PM
    tundracap
    NC
    I believe I have seen that. Need to look at it again.
  5. Jan 3, 2019 at 5:57 PM
    Sunnier
    Sunny
    San Diego, CA
    Hey, @First World Problems Fab , I don't know how much longer I can pimp your potential, Buddy!
    Any chance you want to get going on some Tundra fab? There are hundreds of us that would buy your shizzle....
  6. Jan 3, 2019 at 6:02 PM
    tundracap
    NC
    Been looking at those too, since they are a forum vendor.
  7. Jan 3, 2019 at 6:35 PM
    tundracap
    NC
    Not cheap. I would need at least a pair, with the extension.
  8. Jan 3, 2019 at 9:01 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Sunnier likes this.
  9. Jan 10, 2019 at 10:51 AM
    First World Problems Fab New Member
    Zac
    FirstWorldProblemsFab.com
    2013 Tacoma Locked DCLB
    3" lift , all round armor, skids, 295s, locked axle swap, etc...
    Yes i have a couple mounts that work on the tundra platform currently...
    http://firstworldproblemsfab.com/item/hi-lift-jack-mount
    https://youtu.be/9I-38Lcy0-w
    http://firstworldproblemsfab.com/item/universal-mounts
    http://firstworldproblemsfab.com/item/head-rail-roto-pax-mounts
    both the tacoma and tundra have flad head boards in the bed so these 3 mounts work with both.
    http://firstworldproblemsfab.com/item/bed-rail-tab-single
    These can be used for additional tie down points or if you want to mount a LED pod you can flip them over and mount your pods.
    And they are pretty strong too.
    https://youtu.be/syW47ADiJL4
    I also have a set of corner mounts that i just released that will also work. They can be used as additional tie down points, and there is a hole that can be used as a CB / LED pod mount.
    I need to get some decent photos of them so i can put them up on the site.
    Sunnier[QUOTED] likes this.
  10. Jan 10, 2019 at 10:58 AM
    Zac
    Also what is it that you guys are trying to mount? Are you looking specifically for stuff you can use on the side rails more than the head rails?
  11. Jan 10, 2019 at 11:03 AM
    Sunnier
    Sunny
    San Diego, CA
    Yes. I tagged you because I've followed you since your introduction post, so when I see members looking for ways to mount Anything to the OEM side rails, I remember you were gonna look into it, and that another member not too far from you offfered to meet up with his Tundra. I read all over this thread, so I see guys asking about solutions all the time. Figured I'd tag you to see how it's comin', whether you were able to work out that your side rail mounts for Tacoma work for Tundra.
    P.S. Thanks for checking in. I hope all is well!
  12. Jan 10, 2019 at 11:12 AM
    Zac
    Yeah i just need to take some cardboard so i can mock up a design and get some measurements. And meeting up with people is like trying to meet up with people from dating sites. You can talk all day long but when i comes to actually meeting up its like pulling teeth from a wild boar. haha.
    The only way i was able to verify that my mounts work is because i went to a public event and happened to see a tundra with bed rails and i happened to have my mounts in the truck.
  13. Jan 10, 2019 at 11:17 AM
    tundracap
    NC
    What I really want are MOLLE panels for inside the bed sides. Something that will mount below the factory bed rails, under and closer to the inside sidewall, and not flush with the bed rails.
