Bouncy at 75-80mph
Discussion in '2.5 Gen Tundras (2014-2021)' started by matambo, Oct 11, 2017.
  1. Oct 11, 2017 at 9:08 PM
    matambo
    matambo [OP] New Member
    2017 Tundra 4x4
    so i got my first truck - a 2017 Tundra Crewmax 4x4 with the TRD package. stock 18" wheel with 275/65/18.
    took the truck for a cruise at i25 here in denver and i notice that the car bounces when reaching 75-80 and after 80 its smooth sailing again and vice versa when slowing down. are my tires over inflated or is that normal for trucks to do.
    any suggestions? would installing a rear sway bar fix this? i also have ordered 285/55/20 nit tires with 20 x 9 rims. would the bigger wheel and tires solve this? need advise....
  2. Oct 11, 2017 at 9:32 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Was it a concrete highway? Sounds like bed bounce. Bigger wheels won’t help, might actually make it feel rougher.
  3. Oct 11, 2017 at 9:38 PM
    BayRunner
    2017 Tundra Platinum
    How much air do you have in the tires? Low psi on a P rated tire can feel like a sponge in the right conditions.
    matambo[QUOTED][OP] likes this.
  4. Oct 11, 2017 at 9:55 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Tires may need speed balancing. That's what it sounds like to me.
    Les7311 and matambo[OP] like this.
  5. Oct 12, 2017 at 3:01 AM
    matambo
    2017 Tundra 4x4
    yup concrete highway. bed bounce?
    040Tundra likes this.
  6. Oct 12, 2017 at 3:02 AM
    matambo
    2017 Tundra 4x4
    would have to check on that too. thanks
  7. Oct 12, 2017 at 4:29 AM
    borntostun
    borntostun New Member
  8. Oct 12, 2017 at 4:47 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Maybe it just the adrenaline pushing your lead foot. Lol
    matambo[OP] likes this.
  9. Oct 12, 2017 at 5:26 AM
    Yep, it is the roads. Only thing you can do is suspension tuning. Have you tried that speed on other roads?
    Where are you going 75-80 mph on I25 in Denver? It is usually stop and go.
    040Tundra and matambo[OP] like this.
  10. Oct 12, 2017 at 5:30 AM
    matambo
    2017 Tundra 4x4
    to castle rock. suspension tuning? like sway bar?
  11. Oct 12, 2017 at 5:30 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    this was my first thought as well.
  12. Oct 12, 2017 at 5:32 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    some weight in the back might help as well. once i put the topper on mine, it started to settle. then really settled with the drawers, kings and new leaf packs...
  13. Oct 12, 2017 at 5:46 AM
    A sway bar will make it worse.
    You will need to upgrade to a shock that is tunable, and the rebound will have to be adjusted. Call the guys at Filthy Motorsports in Denver.
    You have a two fold problem.
    1) rear part of the frame is flexy.
    2) factory shock on vehicles suck.
    The expansion joints on the freeway are almost the wheelbase of a truck. Colorado should not have concrete highways.
  14. Oct 12, 2017 at 6:31 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I had the same problem until I changed the rear shocks and the bed bounce went away by half, at least. I need to do what @smslavin did to his ride!! Then I’ll have no bed bounce. Good thing our freeways aren’t that bad. Only one section of one of the freeways that I travel on actually.
    matambo[OP] and ColoradoTJ like this.
  15. Oct 12, 2017 at 7:06 AM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    That particular stretch, 25 from Lincoln to castle rock, is real bad for the bounce....
  16. Oct 12, 2017 at 7:08 AM
    That is because Nevada knows how to build concrete highways.
    040Tundra[QUOTED] likes this.
  17. Oct 12, 2017 at 7:13 AM
    matambo
    2017 Tundra 4x4
    so mine is not an isolated case with tundra trucks.
    ColoradoTJ likes this.
  18. Oct 12, 2017 at 7:13 AM
    matambo
    2017 Tundra 4x4
    cool. what rear shocks did you use?
  19. Oct 12, 2017 at 7:15 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    My 2016 does the same in Denver. Especially on 285 going up to the mountains. 7500 miles on mine. Stock TRD off road suspension.
  20. Oct 12, 2017 at 7:16 AM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    You're not the only one. Its also bad on the 225 northbound, from Mississippi to the 70...
  21. Oct 12, 2017 at 7:23 AM
    Or some trucks with close to your wheelbase.
    Our 4Runner, Tacoma, GMC is smooth through that section. I still get it a little in the GMC. I'm putting some King 2.5's on the rear for sure.
  22. Oct 12, 2017 at 8:00 AM
    matambo
    2017 Tundra 4x4
    thanks for all the inputs. so how do we remove this? coilovers?
  23. Oct 12, 2017 at 8:32 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    We do have pretty good roads for the most part. They just take forever to build them. Half the time the reduced speed limits are in effect, no one is even working on the stupid road.
  24. Oct 12, 2017 at 8:34 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    They came with my lift kit. They’re the Zone nitrogen shocks. Not really good but better than stock TRD OR. Just until I can put my icons on her.
  25. Oct 12, 2017 at 9:26 AM
    Be glad they take the time and do it right. I would like to blame our roads on the weather changes, but I have had some of the hottest and coldest days in my life training in northern Nevada.
