Bought a RZR and 12' trailer. Truck is a dog!!
Discussion in 'General Tundra Discussion' started by FloridaTundra, May 18, 2020.
  1. May 18, 2020 at 3:40 PM
    FloridaTundra
    FloridaTundra [OP] New Member
    Vero Beach, FL
    2011 Toyota Tundra CrewMax
    7" lift
    I've always had diesels in the past and I've bad them all, but damn this trailer and RZR kill it. 3000 rpm to hold 75mph. Thinking about getting rid of the Yota. I love the truck and love how it looks, but it doesn't pull worth a sh=t
    Theonlyway and Stroke250 like this.
  2. May 18, 2020 at 3:41 PM
    TheBeast The Beach
    did you push TOW/HAUL button ?
  3. May 18, 2020 at 3:45 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    3,000 RPM is nothing to worry about. Its not a diesel :notsure:
    Y0TA PR0, power80, GODZILLA and 10 others like this.
  4. May 18, 2020 at 3:45 PM
    FloridaTundra
    Vero Beach, FL
    7" lift
    Yes. Tow haul the entire time. I understand that the truck catches tons of air all lifted and the 35's dont help but man it's a dog.
    Rica25 likes this.
  5. May 18, 2020 at 3:48 PM
    FloridaTundra
    Vero Beach, FL
    7" lift
    The 3000 rpm doesnt bother me to bad but damn 4000 lbs killed it. Maybe I'm just use to holding 80 up just amount any with 25000 lbs behind me.
  6. May 18, 2020 at 3:54 PM
    Squatting Pigeon
    Holden
    North Texas
    The power band is higher for these trucks, so you have to wind them out a little to get there. Especially with 35s and no regear, she's gonna scream a bit as you get up there and the VVT kicks in.
  7. May 18, 2020 at 3:55 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    A Tundra cannot compete in towing against a heavy duty diesel, even less so with larger tires. Its a different class of truck.
    If you want to do 80 mph towing, you would honestly do better with a domestic diesel.
  8. May 18, 2020 at 3:57 PM
    I have no issues towing with mine. Full steel deck 20' trailer and a Camaro. Do you have the 5.7 motor?
  9. May 18, 2020 at 3:58 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  10. May 18, 2020 at 4:00 PM
    Sp33dNut
    Sp33dNut New Member
    2019 White Tundra DCOR
    Why would you do 80mph towing anything?
  11. May 18, 2020 at 4:03 PM
    Grumpy Uncle
    Pat
    CO
  12. May 18, 2020 at 4:04 PM
    Squatting Pigeon
    Holden
    North Texas
    I bet he's got a hundred grand under that hood
  13. May 18, 2020 at 4:14 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Drive an HD gasser with that load - go up any grade and it's WOT to hold 60 mph. Welcome to the world of towing with a gas engine.
  14. May 18, 2020 at 4:21 PM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    I once towed a uhaul enclosed 12x6 trailer full of furniture with my old 4 cylinder Tacoma 5 speed. Probably about 6k lbs.. That was a dog.....
  15. May 18, 2020 at 4:23 PM
    Bronzeback
    Bronzeback New Member
    7" lift and 35's? I could speculate what most of the issue is.
  16. May 18, 2020 at 4:24 PM
    mountainpete
    Good point. A relative of mine has a GMC Denali dually with the gas engine. He didn’t want a diesel but needed the payload for work. He regularly complains of how it pulls even a 10k load.
    GODZILLA and Cpl_Punishment like this.
  17. May 18, 2020 at 4:46 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    4.6 or 5.7L? There is no comparing any of the diesels you used to own to a 9 year old gas engine half ton pick up truck. Sorry for your disappointment but you should have expected it. 35s & doing 80mph...come on man :confused::rofl::notsure:
    You probably wanted 15mpg doing it too I'm sure
    DZ_, 831Tun, Terndrerrr and 7 others like this.
  18. May 18, 2020 at 4:46 PM
    I tow all kinds of stuff with mine all the time with zero problems getting the job done. Oh and I am on 35's also.
  19. May 18, 2020 at 4:49 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Re gear the truck and then come talk to us.
  20. May 18, 2020 at 5:31 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    80mph with a razor on a trailer that sounds too small seems like the bigger issue here. 3k rpm is no big deal.
  21. May 18, 2020 at 5:32 PM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    I had this same issue. Loved my Tundra but after owning diesels for over 15 years you get accustomed to the ease of towing with them. I went back to my roots and into a diesel again.
  22. May 18, 2020 at 5:32 PM
    Squatting Pigeon
    Holden
    North Texas
    Yeah you gotta see 95 at least before passing judgement
  23. May 18, 2020 at 5:45 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Do you have a windsheild on your rzr? If so that and the 35's are the problem I'd suspect. Also try it without tow haul, you dont need it for a load that light.
    I tow my honda pioneer 1000-5 with windshield on an 18' tandem axle without issue, but I have 33's and dont use tow haul.
  24. May 18, 2020 at 5:54 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Seriously 4000 lbs ! Lots of people towing between 5-10 k...
  25. May 18, 2020 at 5:59 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    I would disagree.. I pulled a 7500lb trailer from Mississippi to Washington and had no issues going through the Rockies.. I used the S mode to make it so that the engine couldn't get to 6th gear..
    You may want to hit the Tow/Haul button.
    chugs, Bigolbaddy, Black Wolf and 3 others like this.
  26. May 18, 2020 at 6:05 PM
    belanger9
    Edmonton, AB
    A bunch
    People who are used to diesels sometimes don't understand the difference. Pull 10k lbs with a diesel and it just yawns at you for thinking it has to work, pull even that little weight (3k lbs) in a gasser and it revs higher making it feel like it's working harder. Takes some getting used to for sure.
  27. May 18, 2020 at 6:13 PM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    I redline my shit, bouncing 7k on that tach all day long:fingerscrossed:
    Rock15t and jeremyd like this.
  28. May 18, 2020 at 6:48 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Noob here: could you please explain the disadvantage of towing a lighter load in tow/haul mode?
    15whtrd and Tundyfundy like this.
  29. May 18, 2020 at 6:56 PM
    FloridaTundra
    Vero Beach, FL
    7" lift
    Yes the 5.7
    GODZILLA and Rica25 like this.
  30. May 18, 2020 at 6:58 PM
    Surprised you have towing issues with that tiny toy.
