Bought a dashcam, I want to wire it differently
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Shaggypeach, Jul 8, 2018.
  1. Jul 8, 2018 at 4:51 PM
    Shaggypeach
    Shaggypeach [OP] New Member
    Hello all
    Recently purchased a dash cam for $50 on Amazon during a sale. I figured why not. It is mini usb to cigarette lighter and I very much rather not have that hanging out in the dash or see any cables.
    This is the cam I bought and it plugs from the left side. I was looking at this. Anyone has done it? Thoughts? Suggestions?
    Silv333 and dcsleeper408 like this.
  2. Jul 8, 2018 at 6:11 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Yes it will work fine. Use an ignition controlled fuse. Like the cig lighter. Great way run it up in the headliner down apillar down to the kick panel fuse box. There you can add a fuse.
    BuckWallace and Freak Show like this.
  3. Jul 8, 2018 at 6:14 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Yep, thats exactly how I ran mine, just like dcsleeper said.
    dcsleeper408 likes this.
  4. Jul 8, 2018 at 7:22 PM
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    I used that Hard Wiring kit that you have there also. Only difference is that I wired mine into a Always Hot circuit. Because I use mine in Parking Mode for Surveillance. I believe it has a built in Low Voltage shutoff to protect from a Dead battery.
  5. Oct 28, 2018 at 7:16 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    I was thinking of taping into the lights on headliner where the sunglasses holder is
  6. Oct 28, 2018 at 7:26 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Would love to see pics of the wiring and install.
    phabej likes this.
  7. Oct 28, 2018 at 7:44 PM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    I found ignition switched power from the overhead console. From the rear view mirror if I recall correctly. No pics needed as it's just a black wire coming out of the headliner.
  8. Oct 28, 2018 at 7:49 PM
    Freak Show
    Freak Show New Member
    Wayne
    2018 Silver Sky Metallic 5.7L SR5 4x4 TRD Double Cab
    If you have parking mode and intend to use it, I recommend the Vicovation Vico Power Plus. You can set it to shut off when a certain voltage is reached, when a certain temperature is reached, and/or after a certain amount of time.
    banana_phone likes this.
  9. Oct 28, 2018 at 8:06 PM
    FoghornTX
    FoghornTX Proud American and Infidel since 1968
    Ft Worth, Texas
    2022 Camry XSE (Black w/blackout package)
    At some point, car manufacturers will put a USB/12v power port behind the rear view mirror.
    geno0506 likes this.
  10. Oct 29, 2018 at 11:27 AM
    PMG
    PMG New Member
    I did that with the wiring harness to the fuse box and also wired a radar detector with power from the mirror.. you could wire it either way.. Search for PMG's Tunny thread.
  11. Oct 31, 2018 at 10:13 AM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    I tapped my fuse the other day and ran the wire up and over but didn't take any photos.. sorry.
