bottle jack ?
Discussion in 'Recovery & Gear' started by TheBeast, Oct 7, 2018.
  1. Oct 7, 2018 at 10:51 AM
    TheBeast [OP] The Beach
  2. Oct 7, 2018 at 10:54 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I got a 10 ton one at harbor freight. It was fairly inexpensive. Fits in the esp under seat storage good.
    equin and TheBeast[OP] like this.
  3. Oct 7, 2018 at 11:16 AM
    Vizsla
    Vizsla 2 = 2.5
    I have the first one you linked. Not going to fit where the stock one does. Only used it a few times, but it worked well, is compact, and can lift my truck high enough to change tires with minimal sketchiness.
    GodlessPro, 831Tun and TheBeast[OP] like this.
  4. Oct 7, 2018 at 11:18 AM
    @Vizsla thanks. do you position it under rear axle to change rear tires for example ? how about front ?
    not too short for 3/1 with 35's ish height ?
    Vizsla[QUOTED], GodlessPro and 831Tun like this.
  5. Oct 7, 2018 at 11:20 AM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I bought the first one but haven’t used it yet. On one of the BASTRDS runs someone used one and I ordered it as soon as I got home.
    TheBeast[QUOTED][OP] likes this.
  6. Oct 7, 2018 at 11:27 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Like Matt, @GodlessPro said, got to see one used on the trail. The truck (@Tundra4us) has a bracket lift and the jack was able to lift it fine.
  7. Oct 7, 2018 at 11:28 AM
    thanks guys ! looks like a serious contender and priced well.
  8. Oct 7, 2018 at 11:37 AM
    Vizsla
    Vizsla 2 = 2.5
    Actually using it right now since I decided to build my own leaf springs:rofl:o_O. Here are a few pics. This is on the middle setting, at max it lifts 21”.
    Tundra4us, equin and GodlessPro like this.
  9. Oct 7, 2018 at 11:38 AM
    GodlessPro
    Matthew
    NorCal
    I couldn't remember who it was. Good memory Warren.
  10. Oct 7, 2018 at 11:59 AM
    Vizsla
    Vizsla 2 = 2.5
    Sorry should of added, for the front I usually lift by the frame. At 21” lift it is a hair short of being able to change the tire. I carry some 4x6 wood blocks for the front, also reduces jack extension.
    equin and TheBeast[QUOTED][OP] like this.
